I bought an e-Bay TT column for my '75. I had to buy everything above the extention (#10), because none of the upper parts were included. I re-built the whole column using Mr. Shea's papers, (a GREAT help), but now with the "horn contact spacer" (#8) mounted under the "lock ring" (#7), I have a large gap between the wheel and the lock ring! It almost looks like it would fit better wothout the spacer, but then the star screw and/ or the lock rod seem to be too long.
Any help? i can try to post a picture if I can figure out how. Thanks much!!!
Dave
I bought an e-Bay TT column for my '75. I had to buy everything above the extention (#10), because all none of the upper parts were included. I re-built the whole column using Mr. Shea's papers, (a GREAT help), but now with the "horn contact spacer" (#8) mounted under the "lock ring" (#7), I have a large gap between the wheel and the lock ring! It almost looks like it would fit better wothout the spacer, but then the star screw and/ or the lock rod seem to be too long.
Dave
Thanks, dobroman.
Your 3rd. and 4th. pics look a lot like mine. It just seems like the gap between the wheel and the lock ring is too big, but I might be wrong. I've never had a TT column, so I don't have anything to compare it to.
I can't figure out how to post my pics, so I e-mailed them to Jim Shea in hopes he can look and see.
Thanks, dobroman.
Dave
He's the one that helped me with my change... He's around so hopefully he can get you fixed up!!
I rebuilt the tilt/tele column in my '72 last year. After I got it all assembled it seemed my lock ring had quite a gap between it and the steering wheel that I don't remember being there before. I tried different ways to get the lock ring closer but didn't have any luck. So I just chalked it up to a bad memory and that's the way it was when I disassembled it. I know this is of no help, but I thought I'd throw it out there. If you happen to come up with the answer I would greatly appreciate if you would post it.
Thanks.
I'm just going to assume it's correct, because I've never had a TT column before.
Jim Shea replied to an e-mail I sent, but my pictures didn't go through for him.
At least I can install it back into the car.
