rough running at low revs
Old Mar 3, 2009 | 05:42 PM
Rob vette's Avatar
Rob vette
Default rough running at low revs
Hello my B/B is running with a slight miss at between idle to 1600 rpm then clears and cruises fine at all rpm range I have replaced plugs /points/ checked timing/ to me it feels like a fuel problem?any ideas of where to start?
Old Mar 3, 2009 | 05:46 PM
midyearvette's Avatar
midyearvette
if you are sure of the ignition system including the plug wires and you have no arcing or a bad cap, then i would spray sone carb cleaner into the idle air bleeds atop the primary boosters with the mill running, to start with....good luck
Old Mar 3, 2009 | 07:55 PM
Rob vette's Avatar
Rob vette
I forgot to mention the carb. is a Q-jet and was re-built 3 years ago I checked the fuel filter and is clean it feels like a flat spot then clears it self and when it does it is when I leave from a standing start?
Old Mar 3, 2009 | 09:29 PM
midyearvette
accelerator pump........
To rough running at low revs
