Tach does not work on real cold mornings
Dan
82's don't have a cable, the tachs are electronic. Not sure exactly what would cause your tach to be slow to operate, but problems with 75-82 electronic tachs can usually one of two things. These are the tach filter or the circuit board in the tach.
The circuit boards are available for about $60 from most parts vendors and come with instructions on how to recalibrate your tach when done installing the board. The tach needs to be removed from the dash to install the board, but it's a pretty simple task. Replacing the board will probably fix your accuracy problem. The tach filter is found under your hood, on the right side of your engine, near the distributor. Repros of these were supposed to be in the works, but I don't know if they're on the market yet.
Someone on the forum with more experience with automotive electronics, may be able to help you further.
Tack is electronic/Speedo is machanical
Hope this helps
Hey, I know Jersey is cold! I spent time at Naval Weapons Station-Earle. I know all about the cold weather up there.
Dan
Dan
Remove 4 screw in panel under steering column and loosen the 2 bolts that hold up the column. This will allow the steering column to lower which will be eaisier to remove.
Remove screw that hold speedo and tach to dash
Disconnect speedo cable and pull guage section out and disconnect electrical harness at back of cluster.
Remove lense cover
Remove black allen screws to remove black facia
Remove 2 or 3 three screws that hold the tach to the cluster (back of cluster)
Remove nuts that hold circuit board to tach.
On my 78 I anticipate using this write up for 75-82 tach board removal. Appears to be different than Spedaleden. Perhaps it is not correct for some years? Good luck.
http://www.corvettemagazine.com/2005.../tach-lead.asp
On my seldom driven 78SA the tach seemed stuck. It was. Took the clear lense off in preparation for tach removal but gave the needle a nudge first.
Works fine now! The needle is very sensitive. I believe I once heard someone refer to it as a fluid drive(?).
I DID need to replace boards in 2 other Vettes. Both had bad chips and weren't repairable. Member Aceco repairs boards if the chip isn't fried.
