lowering spring?
Old Mar 5, 2009 | 04:47 PM
dburgjohn's Avatar
dburgjohn
Default lowering spring?
Does anyone make a spring to lower the rear of a 81? I used the longer bolts for as far as it is safe to go and stay out of the tire. It could use another inch or two down.
Old Mar 5, 2009 | 06:24 PM
1nicecorvette's Avatar
1nicecorvette
you can use a shorter spacer in between the spring mount and differencial
Old Mar 10, 2009 | 11:25 PM
dburgjohn's Avatar
dburgjohn
Default So...
so there is no spring with less arch that could lower car without getting into tires?
To lowering spring?
