82 Poly Body mount help.
Old Mar 7, 2009 | 10:21 AM
getvrtcl's Avatar
getvrtcl
Default 82 Poly Body mount help.
I have the body back on the frame with new poly mounts, BUT I am not sure if there are any torque specs I should follow. Has anyone got any advice?
Old Mar 7, 2009 | 11:06 AM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
I'v never saw any when I installed mine,, I don't think you have to worry to much about over torque,, its not like rubber were you can squish the crap out of them, the poly are very stiff. I do remember tightening them very good, you definatly don't want any play, considering the weight of the body and the forces on the road you want them to be tight.
Old Mar 11, 2009 | 07:20 AM
getvrtcl's Avatar
getvrtcl
I also think that the inner sleeve will keep anyone from "squashing" them too much.
The only reason I asked is because I accually read the directions and it stated "retorque to ariginal specs. I should never read the directions.
Old Mar 11, 2009 | 11:28 AM
Michel B's Avatar
Michel B
LoL,,, I have a bad habit of reading instructions after I break it for sure you can't go wrong following all torque specs,, .
Old Mar 11, 2009 | 11:55 AM
GDaina's Avatar
GDaina
rule of thumb use the torque spec for bolt diamater and grade...
http://www.raskcycle.com/techtip/webdoc14.html
To 82 Poly Body mount help.
