Intake match for 402
Old Mar 7, 2009 | 12:35 PM
base1957's Avatar
base1957
Default Intake match for 402
Ok got a 402. It had proform750, edel performa 20 intake, has 10:1 compression pop ups, head is 454 cast, mild to mid cam.
I've been told go with quick fuel 750 carb, my question is what intake manifold do you suggest.
great forum here I'm a rookie and alredy gotten lots of good info thanks
Old Mar 7, 2009 | 01:09 PM
DRIVESHAFT's Avatar
DRIVESHAFT
If you have the clearance under the hood, the Performer RPM would do nicely for you.
Old Mar 7, 2009 | 02:39 PM
base1957's Avatar
base1957
will go in a 68 vette with a big block hood
Old Mar 7, 2009 | 05:00 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Not much is going to fit under the std. big block hood. You would need the L88 hood to clear the Performer RPM.
Typically the only aftermarket intake known to clear the normal hood on a big block is the Torker 2.
To Intake match for 402
