Power Steering Pump and Pulley
Old Mar 7, 2009 | 11:22 PM
willem wallace's Avatar
willem wallace
Default Power Steering Pump and Pulley
I have a Saginaw power steering pump with the cast iron, three spoke pulley, GM part #3834720. I think these were used 65 thru 74 small block w/o a.c..
So, my original plan was to pull this pulley and mount it on a new production "Tuff Stuff" Saginaw pump from Summit, for installation on my ZZ383. First off, what is the correct way to remove this type pulley without damaging it? I rented a power steering pulley removal tool, but it was designed for a pressed on straight shaft application, mine is a tapered shaft with a locknut threaded on to hold the pulley. Second issue, I am just assuming, but it would be my guess that the "Tuff Stuff" pumps are not available in a tapered shaft/lock nut configuration.. I really have no interest in rebuilding this pump, was hoping to use this pulley on a newly manfactured unit. Any suggestions?
Any info is appreciated!
Old Mar 8, 2009 | 11:39 AM
willem wallace
ttt
Old Mar 8, 2009 | 08:00 PM
willem wallace
ttt
To Power Steering Pump and Pulley
