Engine dying at High RPMs?
Anyways, I have a problem that I was hoping to get advice on. I'll give the symptoms and what I've researched on the problem so far.
I was cruising down Interstate 24 the other day around 90mph and pressed the accelerator and the engine started sputtering, sounded like it was fixing to die. I backed off to around 90 again and it was fine. A repeat test proved the same thing, once again when throttled past 90mph, I believe around 4k rpms, the engine started to die. So I dropped down to 70 and it was fine all the way back to my exit. Wanting to know if the problem was universal through all gears at high RPMs, I stopped at a light and opened up the throttle enough to hit the target, problematic RPM range in first gear and sure enough, more sputtering around 4k-4.5k
Recap:
Sputtering Engine around 4k rpms universally, anything less is fine.
Things to note:
I recently replaced the 2ft section of "supply" fuel line in the back of the car and have inspected connections at the fuel pump, carb, and as far back as possible to the tank, I have also looked at the fuel pump and it "Looks" fine, even though everything looks fine from the outside. I have not tested the pressure on the fuel line though I doubt that would reveal any results unless I tested pressure at about 4k rpms which my neighbors wouldn't like very much. It's the stock L-82 350 engine, I can answer any other questions as needed. Also, does anyone know where the fuel filter is located in the 77? Pictures by chance? thanks.
A friend told me that the new 10% ethanol in today's gasoline breaks up any present residual rust inside of tanks which can clog the filter, so we'll see if this problem re-occurs in a few months.
It was interesting to change the filter inside of the Quadrajet Carb, most of the ones i've done where external somewhere in the line between the pump and the carb.
PS. Sock in the gas tank? What's that?
Rgds. Roger.
Not necessarily true. I had a problem with my '64 doing the same at the big end of the quarter. I put a pressure guage on the line and found only 3#. I changed out the fuel pump, the pressure came up to ~7# (even at idle) and the car runs great.
