81 dimmer switch.
Old Mar 10, 2009 | 12:01 AM
ramair_bryan's Avatar
ramair_bryan
Default 81 dimmer switch.
Hi guys..........ramair here. I always read, but seldom post. So dont worry, I,m around. Todays question is...............I removed the ign switch, signal, horn, etc. and now getting it all back together is, well different. Can't make the signal/dimmer lever contact the dimmer push rod. I must be missing something. Got pics I can check? thanks in advance...........bryan.
Old Mar 10, 2009 | 07:34 AM
Jim Shea's Avatar
Jim Shea
Here is a one page pictorial on assembly of the T&T steering column head with a dimmer pivot (shown in picture #4). The part called the actuator connects the dimmer rod to the dimmer pivot.
Also 1969 through 1982 Corvette Tilt & Telescoping Steering Column Disassembly & Repair Paper #3 says the following:
Reassembly - Dimmer Pivot and Actuator
Install the dimmer pivot to the lock housing cover. (Early dimmer pivots were retained by a long bolt, later pivots used a press fit pin.) On 1977 columns route the wash/wipe switch wires down through the column. Assemble the plastic dimmer rod actuator to the end cap using some heavy grease. The actuator is guided between the end cap and the metal housing and is retained during assembly by the grease on the little square post inside the cap. Without the grease, the actuator is very difficult to hold in place while reassembling the column because the wire rod isn’t exactly tightly fixed in position.
Jim
Old Mar 11, 2009 | 11:46 PM
ramair_bryan
Default jims advices good.
Jim
Thanks jim for the diagram. Your not kidding that part is difficult to install. I have the feeling I'm going to go around with just low beams for a while........I'll try again later on. Have to repair other stuff at the moment. thanks again.........bryan.
Old Jan 23, 2019 | 09:02 PM
Danny Halperin's Avatar
Danny Halperin
Jim
HI I TOOK THE BOX COVER OFF I NEED TO PUT BACK ON. SAYS TO GREASE DIMMER SWITCH TO INSIDE THE BOX COVER OVER THE LITTLE SQUARE , BUT THERES A RETAINING METAL CLIP THAT FELL OUT. NOT SURE WHERE THAT GOES
To 81 dimmer switch.
