Vacuum line photos
Old Mar 10, 2009 | 04:01 PM
JB Vette Man's Avatar
JB Vette Man
Navigator
Default Vacuum line photos
Hey guys.
Anyone have a picture of the 79 style L-82 vacuum diagram or on the car?
Old Mar 10, 2009 | 07:28 PM
1nicecorvette's Avatar
1nicecorvette
for which system?
Old Mar 10, 2009 | 07:39 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Old Mar 11, 2009 | 01:41 PM
JB Vette Man
Navigator
Sorry for being vague...not the headlights but the intake carb etc vacuum system. That diagram is great for the headlamps....
Old Mar 11, 2009 | 06:45 PM
1nicecorvette
DEPENDING ON WHICH ENGINE YOU HAVE . 3 VERSIONS IN THE AIM. THIS WILL WORK FOR YOU
Old Mar 13, 2009 | 10:10 PM
Code Blu's Avatar
Code Blu
Default Vacuum Question
Hi guys, I just installed a Holley 670 on an Edelbrock RPM Qjet manifold. The vacuum port in this manifold sits right under the carb. Can I install the the vacuum for the lights and the trans to a port on the carb? or should I get some kind of adapter and fit to the manifold.
Old Mar 14, 2009 | 08:21 AM
TXredc3's Avatar
TXredc3
I did. I have a holley carb that sit over the vacuum port on my manifold. I hooked up the vacuum lines for the lights and brakes straight off the back of the carb. I don't have an auto tranny so maybe this would be too much for the one port. I do have a lumpy cam so my vacuum is low anyway. However, everything works fine. I'd give it a try. If you notice you're not getting enough vacuum to run all three then you know you need a second vacuum port. I'm not sure how much clearance you have between the top of the manifold and the bottom of the carb, but I do know that they sell shorter ports that screw into your manifold. Check with Napa. If that doesn't work then you can always drill a new hole in your manifold.
Old Mar 14, 2009 | 03:29 PM
Code Blu's Avatar
Code Blu
Thanks for the feedback. I will try Napa and see what they have for an adapter. I will do that first before going to the carb, which means increasing the length of the lines.
To Vacuum line photos
