tail light/blinker problem....help
Old Mar 12, 2009 | 01:18 AM
remmy379's Avatar
remmy379
2nd Gear
Default tail light/blinker problem....help
Hello all. I have a 1976 Stingray that I recently purchased. I have been having trouble with a slow left blinker when my headlights are off and no left blinker or left brake light when the headlights are on. I have replaced all fuses except for the acc fuse, which continuously pops when i put it in. I have also replaced the flashers and checked the brake light switch, which I believe is making contact and functioning properly (right brake light illuminates). Both headlights, sidemarkers, emergency flashers, and tail lights operate properly (left dimmer that the right).......Any ideas guys?
In addition, my radio isn't functioning. Any ideas on where to start looking?
Thanks so much.....Tony
Old Mar 12, 2009 | 02:09 AM
Z-man's Avatar
Z-man
I'd check your voltage - make sure it's adequate ( > 13 v). Then look for bad grounds with bad wires, rust at the connections, ground wires from the lights, etc. With the acc fuse popping all the time, you've got a short in that circuit somewhere - chances are that the other circuits are not quite up to snuff either.
Old Mar 12, 2009 | 03:54 AM
Young69Owner's Avatar
Young69Owner
Radio should have a yellow power wire. Check all your fuses and I agree with the above post. That's why old British cars had all those problems with the Lucas Electronics... If nothing else works, replace the bulbs. I know it doesn't make sense, but sometimes it just doesn't...
Old Mar 12, 2009 | 10:41 AM
KevinK's Avatar
KevinK
Check out the great advice I got in my thread, titled "Brakes lights stopped working".
Maybe you have the same problem I do.
Old Mar 12, 2009 | 11:02 PM
remmy379's Avatar
remmy379
2nd Gear
Thanks guys..gonna get started on the quest this weekend.
Old Mar 13, 2009 | 01:09 PM
sgm2004's Avatar
sgm2004
remmy,check to make sure the bulb is in the socket correctly. NS this little thing drove me crazy for a week until I pulled the bulb and installed it properly. Thanks
sgm2004
To tail light/blinker problem....help
