? on priming the oil pump (small block)
Old Mar 14, 2009 | 01:44 PM
dmayhew's Avatar
dmayhew
Default ? on priming the oil pump (small block)
I was recently told by a local car guy that when priming the oil pump to get oil to the mains and rockers arms on an initial start yp after installing a new cam that I jave to use a old distributor and not a simple rod that will spin the pump shaft.
He said that the simple rod would only send oil to the mains and not to the top of the notor.
He said that a old distributor w/o the cam gear would send oil to the top of the motor.
Is this correct? and what is the difference that causes this to happen?
David
Old Mar 14, 2009 | 01:59 PM
'75's Avatar
'75
Where the distributor fits into the block it will direct the oil to the upper end rather than letting it dump down the distributor hole. Many auto parts stores have this tool for loan.
Old Mar 14, 2009 | 02:20 PM
QuicheLorraine's Avatar
QuicheLorraine
David
David if you think about it, your 'car guy's statement makes no sense at all. If you are spinning the shaft and the pump is pumping oil, it cannot possibly make any difference WHAT YOU ARE USING TO SPIN THE SHAFT!
Once it's spinning and the pump pressurizes, oil will get through the motor if you do it long enough and fast enough. Also rotate the engine 180 degrees, and re-pressurize it.
Watch your oil pressure guage, or at the very least leave the rocker covers off & don't stop spinning it until there is oil at the top.
Old Mar 14, 2009 | 02:33 PM
GDaina's Avatar
GDaina
Actually using the distributor with the cam gear ground down is better than just a priming rod...I bought the rod, it's a piece of junk..it wobbled all over the place and threw up oil through the hole.
If anyone wants this pos ****, it's theirs...nothing like a distributor to prime the top end...
Old Mar 14, 2009 | 02:57 PM
SteveG75's Avatar
SteveG75
WRONG.
You need a priming tool or old distributor shaft. The reason for this is that the priming tool/distributor has the plug that distributes oil to both sides of the system. Look at the tool below:
That part replicates the bottom of the distributor shaft and ensures that oil gets to both lifter galleries. Look right above the cam gear.
Old Mar 14, 2009 | 03:08 PM
willem wallace's Avatar
willem wallace
Default Pump
Summit Racing part #SUM-901010, Good quality pump,$17.00 plus shipping. Just add it into your next order. You will spend that much in time,converting an old distributor.
Old Mar 14, 2009 | 03:36 PM
midyearvette's Avatar
midyearvette
true ..the rod alone will NOT do the job you are looking for.....
Old Mar 14, 2009 | 10:57 PM
tfi racing's Avatar
tfi racing
Correct,on a Chev you MUST have the modded old distributor or the tool to get oil pressure.It is also a good idea to give the crank a turn or two with a breaker bar during the priming process so all the passages see oil.
Old Mar 15, 2009 | 12:12 AM
fauxrs2's Avatar
fauxrs2
it makes a huge bit of difference, without the correct priming tool - or the modified distributor, no oil gets where it needs to be...the distributor body actually is part of the oil gallery, without it, or the proper tool ....well you get the point
Old Mar 15, 2009 | 04:14 AM
QuicheLorraine
Originally Posted by SteveG75
WRONG.
Wow I just learned something new! WOW!~ Thanks for setting me straight.
Old Mar 15, 2009 | 09:34 AM
dmayhew's Avatar
dmayhew
Thanks for the detailed answer dauxrs2
The body of the distributor being part of the oil gallery is what I was not aware of.
I will take this advice.
David
To ? on priming the oil pump (small block)
