Installing a new front end/ Help anyone?
http://www.corvette-restoration.com/
Good luck>
I put the inner skirts on first. They attach to the radiator support, which attaches to the removable crossmember, which attaches to the removable frame horns, which attach to the front of each frame rail. I assume you have all those parts.
After you have the inner skirts attached, you can trial-fit the clip in place. The radiator support establishes the height of the hood, and you basically fit the front clip to line up with the height of the hood. I didn't have a wiper door mechanism, but if you are putting that assembly back in, you can mount that and use it to set the height of the clip at the rear, near the cowl. All the bolts that attach the radiator support, the crossmember, and the frame extensions have some wiggle room and space for washers or shims. I put my clip on, and took it back off several times before I was happy.
You also have to make sure the clip is square reference the ground. I repeatedly measured between the top of the wheel arch and the ground to get it close. You will also have to trim the door gap, which I did little at a time with a cut-off wheel, then a dremel when I got close.
PM me with your email address and I will send you pics of before during and after. I am very happy with the results of my work. I had zero experience with this stuff, and it wasn't that bad!
Temvette72
Laith gilmershell@att.net
I will add more in the email I will send. I am no expert, just an amatuer shade-tree mechanic, so I am certain there is more than one way to skin this Stingray, but mine turned out okay with minimal frustration.
Temvette72
I don't feel like spending the extra $600 on a hood if I can get away with itThanks
Temvette72
Temvette72
Jim
