TPI swap into 1980
shawn
Rick B.
Do a search in C3 Tech for guys that have done TPI and PM them on any questions.
Don't forget to post pics
gather round for this, its alot
I know its old tech, but beleive me when I say it beats the stock L48. (even L82 if yours had that one to start)
The transmission required the yoke from a th350, which is also found on th400, 400e also, to acheive the correct length from transmission to rear diff. If you are going with the factory rearend, probably a 3.55, you would also need this adjustment. I dont recall the driveline it was, but it was either the origional shaft, or the one from the 87 car.
Be prepared for a Huge mess of wires, mind you the extra electronics must go somewhere, which if you get an addon computer instead of the one out of an existing car will help ALOT.
The fuel pump, and possibly your tank depending on solution, will need to be changed. Carburretors dont need the electric fuel pumps at the high pressures as do fuel injected cars. The solution on my car was a new fuel tank with an external pump, mounted to the lower passenger side firewall.
Your gauges will not work the same either, you will either need a conversion kit or new gauges designed to work with that distributor/tach, electronic instead of cable for speedo, fuel gauge may need new sending unit, because of the fuel pump deal, and the oil pressure gauge may need a new sending unit or may not.
Your windsheild wipers wont work if you forget the ground strap that goes to the transmission when you change. Your headlights will need to be replumbed for vacuum hook up, wich isnt difficult, and so will your brake booster. there are kits that turn the headlights into an electronic actuator, but are expensive and more time consuming, if your headlights work with the existing engine I would just rerout with new hoses.
Thats all I could think of for all the things that had to be done, hope yours goes well and I didnt scare you lol
Entirely correct about no need to switch transmission, that is just what the previous owner chose to do, since he was using a lower mileage donor car, in this case an 87. I didnt even need to bring that up, I was still thinking about a diffrent topic earlier where someone was planning an engine change.
I agree that you indefinately can with no problem keep the same fan and radiator, although my prefrence is electric. and for the love of all that is good take theese peoples advise about wire harness and computer being waterproof. the guy that did mine before I got it used the 87 corvette harness and computer, and there is a slew of unneded wires.
gauges wouldnt be a problem either aside from maby tach, and the newer system is indeed better,map instead of maf, but will need to be tuned to set the base pressure for your car. there is plenty of room for maf and it adapts to change better in general, but it is not convenient or as accurate.
again Im sorry about the confusion, disregard what I typed about the transmission. This switch will be much more simple than what I typed about. Hope I didnt throw you off too badly.
http://www.jimsperformance.com/carty.html
p.s nows the time to put in a 700r as chip and wire harmess need to be set up
I used Street & Performance for my harness they have been great help thus far! All my gauges work as they did stock, I did not change trans either. Good planning goes a long way!
