Speader bar installation ?
Old May 8, 2010 | 05:58 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Wait until it is back on the ground before tightening it and don't tighten it too tight you just want it snug
Old May 8, 2010 | 08:13 PM
Paul L's Avatar
Paul L
Gardening went by the wayside today as the weather was terrible. So on to the Corvette in the garage. Yes, c69vete was bang on. I jacked each of the front corners up and the shims did not move. Thanks to him for that tip.
I got 90% of the way today. The Wife said STOP when the cuts and blood started to flow . Sirloin steaks OK but not me. She knows what happens when I work on my Corvette. Working whatever wrench in there is a treat. Everything is so tight.
So here are pics. The bar is too close to the fan and I will adjust that tomorrow: the bracket provides movement back for for this. It fits fine under the water pump pulley. Nice product SpeedDirect.
Old May 8, 2010 | 11:12 PM
forvicjr's Avatar
forvicjr
Well, Im building my own spreader bar with heim joints and sleeves. unfortunatly for me its a big block/ serpentine conversion. Guess ill have to get creative!
Old May 8, 2010 | 11:48 PM
69 Convertible's Avatar
69 Convertible
Paul74, did you notch the edge of your fan blades to the spreader bar? Looks like a cutout on the fan blade.
Old May 9, 2010 | 08:10 AM
Paul L's Avatar
Paul L
No, that's just the factory fan. I did not touch it.
Old May 9, 2010 | 04:15 PM
Paul L's Avatar
Paul L
I finished the installation today (we had snow flurries this morning!). I do have a concern that may be groundless but opinions would be appreciated. I will contact Speed Direct tech support. The pulley clearance is OK but the clearance between the fan blades and the bar is about 1/4" and that is with the bracket moved fully back. That seems very close. Does the fan move relative to the bar in operating conditions? If others have similar units with a stock factory fan I would appreciate knowing what your clearance is.
*Edit* - I forgot to remove the blood before the pics. Those who say this is a 10-minute job. Well....
Old May 9, 2010 | 05:30 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
No worries Paul. the motor torque is rotational and that should not be a problem. As for the blades, the faster they go the more they flatten out so the clearence will increase when you are driving.
Old May 9, 2010 | 05:35 PM
Paul L's Avatar
Paul L
Thanks! I'll let people know what Speed Direct says. I suggested they may wish to consider moving the bar mounting points about 1/2" offset from center. That would take care of this issue. Of course I do not expect a reply on Sunday.
There is no interference at idle.
Old May 9, 2010 | 09:50 PM
73jst4fun's Avatar
73jst4fun
Originally Posted by Gordonm
When I put the bar in I just adjusted it out until there was a slight preload on the bar. I did this with the weight of the car on all 4 tires. You do not want to change the camber settings by screwing it to tight and moving the towers out. Just a slight preload is all that is needed.
with Gordon, it's a simple install, on my 73 however I did need to mark the location of the bracket tabs then have the tabs welded...then a slight preload hand tightened.....
Old May 9, 2010 | 09:57 PM
73jst4fun's Avatar
73jst4fun
sorry, wrong button...
Old May 9, 2010 | 10:56 PM
MotorHead's Avatar
MotorHead
Whenever someone says it only takes X amount of time to do something on these dinosaurs I multiply that by 4 and that's just to get everything coordinated to start the job
Glad you got it in, do you notice any difference, feel a bit tighter in the front ?
Old May 10, 2010 | 09:41 AM
Paul L's Avatar
Paul L
I didn't drive the car, it was much too cold. And I am still worried about that small 1/4" gap. Hopefully Speed Direct will get back to me shortly as to whether the bar was designed for such tight tolerances. I have not heard from anyone using spreader bars with factory fans.
Old May 10, 2010 | 10:28 AM
  #33
Green76's Avatar
Green76
Paul, if this works out for you, I'm definetly getting a spreader bar also, I have been holding off getting one because none was made that fit without buying one that has to be welded, I'm also running with a stock fan.
Can't wait to hear what Speed Direct has to say.....
Ulf
Old May 10, 2010 | 01:19 PM
  #34
c69vete's Avatar
c69vete
St. Jude Donor '07
Hey Paul. Here is a pic of how tight mine is. My bar is home made, but you get the idea of how close it is. Been there for more than 5 years and never had a thing there touch. My fan blade is not stock, but the rest is.
Old May 10, 2010 | 03:11 PM
  #35
Paul L's Avatar
Paul L
Thanks for that pic! That looks very close to mine. I have run the engine several times and there is no interference so I'll give it a try. If it rubs at some point I'll just remove it.
As for the ease of installation; slow and tedious. You can get at the rear control arm shaft nuts with an 11/16" deep socket but the front nuts need a ratchet-end wrench. With box or open end...plan on many minutes. Yes, jacking up the frame until the wheel floats prevents loose and perhaps dropped alignment shims. That was a good tip earlier in the thread.
The pic shows the current status. Those little red spots...lots of sharp edges in that area. The Wife bought me work gloves today.
My first charity event of the year (End Women's Cancer) is next Saturday so I hope things work out. As well as the weather. We had frost last night and widespread frost is forecast for tonight. My garage is filled with flower pots around the Corvette.
I have not heard from Speed Direct.
Old May 10, 2010 | 03:32 PM
  #36
MotorHead's Avatar
MotorHead
It's a tight fit because they don't have much room to work with in any direction. Fans should flatten out when spinning, good luck and let us know if you can feel any difference.
Old May 10, 2010 | 05:00 PM
  #37
Paul L's Avatar
Paul L
Thanks, my suspension has been pretty trouble free after I did the rear spring bushings, four shocks, and front swaybar bushings last year. It was a wee bit off before that but whoever did the alignment on this car (before I bought it) knew what they were doing! It tracked just fine in 2008 and even better in 2009 after those repairs. At 70 mph on the highway (last year) I could take my hands off the steering wheel and the car went straight down the road. As to whether the spreader bar will improve things? Perhaps marginally. But that's OK. I just like these little projects.
Speed Direct has replied for which I thank them.
Greetings Paul,
What you are describing is typical. Under loading (while the engine is running) the fan is actually pulled toward to the front of the car thus creating even more clearance. If you are concerned and would like to slot the holes in order to move the bar back towards the pulley, that is certainly ok to do, but not necessary. Please let me know if you have any further questions.
Best regards,
Looks like my installation is typical and acceptable. Let summer begin!
To Speader bar installation ?
Old May 10, 2010 | 06:15 PM
  #38
Corvette.Lover's Avatar
Corvette.Lover
Good news Paul!
Old May 10, 2010 | 07:00 PM
  #39
Paul L's Avatar
Paul L
Originally Posted by Corvette.Lover
Good news Paul!
Yes, sometimes I am too cautious with my Corvettes. It's just a hobby and I don't have the greater knowledge of other people on this Forum. Those folks who do frame restorations for example. I am amazed at their competence. But I don't mind sharing my ignorance of the major issues. Others like me may benefit from my basic skills at the low-level tasks.
Old Jun 7, 2010 | 01:34 PM
  #40
worship79's Avatar
worship79
Thanks for all the very usefull information Paul! Just to make sure; you didn't have to weld with your Speeddirect spreaderbar, but it fit your SB with stock fan?
