Rear shifts left/right when accelerating/decelerating?
Sorry if this is an oft asked question, but I have an odd thing going on. When I go from no gas to a lot of gas (not WOT, just accelerating), I can feel the rear of the car shift left (or the front right, hard to tell), and I have to correct it with the wheel. When I let off the gas, the exact opposite movement happens. I'm trying to figure out what would cause this but I'm really clueless. I thought maybe it was the play in my steering but it doesn't seem like that's right.
Is this a common thing with a known solution or am I just crazy?
-Josh
Edit; Pictures posted below
Well I don't know where the shims are, but I just got under the car and took some pics. Found something weird on the drivers side of the diff too.
Left side trailing arm:
Right side trailing arm:
And the thing that really worrys me on the drivers side of the diff:
Looks like the clamps holding the ujoint in are eating into the drivers side of the diff housing?!?
So it looks like the TA bushings are toast, how do you replace those? And what's the deal with the diff? It's not doing that on the right side...
this is sometimes caused by rotted or wornout rubber bushings at the front of the trailing arms. have a look there...
T-arm bushings are the primary culprit of rear "crabbing", but really all your suspension bushings are likely shot and are contributing to a sloppy suspension.
My car has done the same since I bought it. Coincidentally enough I just ordered a full Energy Suspension suspension bushing set as well as body mounts. I'll be sure to post up my results.
So you have a couple of problems: The TA bushings are toast and the yoke on that one side may be toasted too.
The TA's can be a PITA to do, or sometimes not. Do a search in here and you will find multiple threads on them. With luck all you have to do is jack the thing up and start unbolting stuff and they will come out. If the TA pivot bolts are rust welded to the sleeves in the ta bushing it takes patience and a sawzall to get them out. Deal with that part and then lets take a look at the differential.
Should I really take care of the TA bushings first? I mean the car drives fine and I have no problems with the rear in any situation, but that doesn't look good for the diff and I don't wanna have to replace the whole thing because I let this keep going!
Holy crap! Those bushing are completely shot. I would not drive that car. See those two rusted up flaps on either side of the arm right smack in the middle of your first pic? Those are the shims.
Yep, end yoke play ... you'll need to replace those as well. The half shafts are actually the lower suspension link in the rear.
I don't care what you say. Your car is not driving "fine". I can feel the crabbing in mine too, but my bushings aren't puking out like yours! When you get everything out of there, you'll be able to tell very quickly if the yokes have excessive play. I can almost promise you that yours will. It doesn't look like you've damaged the pumpkin significantly (yet), but I'd stop driving it until you get everything fixed.
Yes, but here's the thing. If your T-arm bushings look like that, then all your other bushings are likely toast as well. I would just go for a whole car package. It'll save you a ton of money v/s buying the bushings piecemeal. The full Energy Suspension kit is only $175 from Summit. Then I also ordered a T-arm mount and shim kit from Ecklers for another $40.
Ok I'm ordering the stuff to replace the bushings. What about the yokes? What do I need to do about that? The bad part about this is while I know a good bit about engines/mechanic stuff in general, I know nothing about the rear suspension or diff/etc.
I can't tell you much on that as I hadn't planned on replacing mine. I'm sure someone will chime in though. Vansteel has remans for $90 with hardened ends. I've been told those are the ones to go for.
The bushings are gone as you know,the side yoke appears to be hitting the housing so you better get the rear suspension out and check it. If the yokes are hitting you're going to need more then new yokes to correct it. Lonestar makes the yokes pretty much all are selling, they have hardened tips. They need to be checked before you install them as well.
Look up my threads with pictures or PM and I'll get you the link.
