77 Corvette Column tilt/telescopic
Old Mar 17, 2009 | 04:01 PM
HT1663WB's Avatar
HT1663WB
Default 77 Corvette Column tilt/telescopic
I have a problem with my column. I took it apart because I had play from right to left, almost like the tilt steering assembly was loose. I replaced the two bearings and tightened the housing, just below the tilt assembly, on the lower part of the column. After putting it back together, I noticed there was very little change. Anybody have an exploded view of the column...or any idea what may be the cause?
Thanks, Bill
Old Mar 17, 2009 | 04:07 PM
noonie's Avatar
noonie
Here is the link
http://jimshea.corvettefaq.com/?page_id=4
Old Mar 17, 2009 | 05:20 PM
Jim Shea's Avatar
Jim Shea
Did you tighten the four screws that hold the tilt support to the steering column? That might be your whole problem.
These three pages of pictures may be of value. You have to look at the third page in order to find the four screws and the support.
http://s2.photobucket.com/albums/y38...1Rev12FE06.jpg
http://s2.photobucket.com/albums/y38...=TTDRPage2.jpg
http://s2.photobucket.com/albums/y38...InstrPage3.jpg
Jim
Old Mar 18, 2009 | 03:29 PM
HT1663WB's Avatar
HT1663WB
Jim
Jim, I checked out your page...I also noticed the lower part of the column is whats moving. The pins come right out with no effort. I didn't even have to use the puller. Should I replace both lower pieces and the 2 pins? I also sent you an e mail...hope you don't mind.
Thanks again for your help
Bill
To 77 Corvette Column tilt/telescopic
