Have been notified that SummitRacing no longer can get these springs. have heard that Crane may be going down.
Can anyone help me locate a set? Need em for my C3 project car motor.
Thanks in advance for your help!!
Doug
Image is a representation of this part. Actual part may vary.
Crane Cams 99896-16
Brand: Crane Cams
Product Line: Crane Double Valve Springs
Part Type: Valve Springs
Part Number: CRN-99896-16
Number of Springs Per Valve: Dual
Outside Diameter of Outer Spring (in): 1.540 in.
Coil Bind Height (in): 1.085 in.
Damper Spring Included: Yes
Spring Rate (lbs/in): 528 lbs./in.
Inside Diameter of Outer Spring (in): 1.140 in.
Inside Diameter of Inner Spring (in): 0.760 in.
Valve Spring Style: Standard
Coated: No
Quantity: Sold as a set of 16.
Valve Springs, Dual, 1.540 in. Outside Diameter, 528 lbs./in. Rate, 1.085 in. Coil Bind Height, Set of 16
I have a used set of CRN-99484 springs that have about a 1000 miles on them. I'm switching to a roller Comp cam and switched the springs as well. Don't know if you can use them, but if you want them, you can have them for shipping only.
CRN-99848-16
Estimated Ship Date: Today
OverviewBrand: Crane Cams
Product Line: Crane Single Valve Springs
Number of Springs Per Valve: Single
Outside Diameter of Outer Spring (in): 1.255
Coil Bind Height (in): 1.153
Spring Rate (lbs/in): 382
Inside Diameter of Outer Spring (in): .870
Inside Diameter of Inner Spring (in): .870
Coated: No
Crane just very recently shut its doors.
Call some of the major performance automotive suppliers see if they have that part # in there stock, if not you have the spring specs you need, the other cam companies can fix you up with a set of springs.
A quality valve spring from any manufactuer will suffice. You just need to focus on height and spring rate issues. I have those springs installed but am looking at swapping to the Comp Cams beehive springs.
Doug
Crane Cams 99896-16
Brand: Crane Cams
Coated: No
Your probably going to need to call another cam company with your cams specs. I don't see the installed height listed on these crane springs. Is this a BB or SB your working on ?
