bleeding the breaks... info please
Old Mar 19, 2009 | 04:31 PM
pauldana's Avatar
pauldana
I think this may be it. I have had the car since almost new, and the original brakes worked great... until one day I had to slam on them and i heard and felt some sort of pop... and ever since then no mater what I do or replace I have that long peddle travel, I have even replaced the peddles themselves. cay you ben the rod? is there a clip somewhere i may have broken? GOD, if their were a C3 brake expert in so cal I would go to him ASAP... got any ideas?
Old Mar 19, 2009 | 08:47 PM
Raptor119's Avatar
Raptor119
Default Rod Too Short
I've worried abouy having a too short of a rod for years.
Old Mar 20, 2009 | 10:42 AM
wcsinx's Avatar
wcsinx
Originally Posted by Tom454
First, anyone who tells you the order is important doesn't understand hydraulics...
So don't get hung up on order... it is irrelevant.
I respect your experience, Tom, and I agree with you in that it won't usually matter. I asked my dad who among other things used to work as a Naval hydraulics engineer, and basically he tells me that bleeding longest to shortest reduces the chance of backflowing air into the system from an empty line. But he does concede that with the distances and pressure you're dealing with in cars, that's a very low probability anyway.
A good, properly functioning proportion valve (misnomer.. it's only a switch)
I don't think that's entirely true. I think in '78? it was changed to be somewhat of a proportioning valve. Prior to that it was indeed just a switch as you say.
Have you ever eliminated this valve/switch from any cars? It seems to be a problematic component from what I've read.
Old Mar 20, 2009 | 10:44 AM
wcsinx's Avatar
wcsinx
Sounds like you blew out the first seal in the MC piston. If it goes, then fluid slides past it and "catches" at the back seal. That'll give you excessive pedal travel. I've never heard of anyone bending anything by slamming on the brakes.
Old Mar 20, 2009 | 12:23 PM
08vycpe's Avatar
08vycpe
I don't know about the newer C3's but I'm trying to recall from 35 years ago when I had a '70. It seems the master cylinder was divided into two halfs with a dam between the halfs. The piston also had two plungers. The idea was that one half of the MC and one seal on the plunger operated the front brakes and the other half and other plunger operated the rear brakes. The idea was that if one half ran out of fluid or there was a leak in the system, the othe half (front or back) would still operate so you could stop the car.
If he blew a seal wouldn't he be stopping on just one set of brakes?
Old Mar 20, 2009 | 12:49 PM
wcsinx's Avatar
wcsinx
No, there's a junction block (the switch/proportioning valve) bolted to the frame that both lines dump into.
You're correct on your interpretation of the piston. But what happens when the front seal goes out is the back seal is now being used to pressurize both lines. That's what gives you excessive pedal travel.
Old Mar 20, 2009 | 01:01 PM
noonie's Avatar
noonie
And if you have 1 master seal go out and also a calipers seal go out on the other half, then you would have no brakes at all.
The proportioning valve or switch combo is soley for regulating the hydraulic pressure for front and back and much more so on a car with rear drum brakes. The off centering of the valve is just a switch that alerts you to a brake failure. You could subsitiute an adjustable valve for the rear system and control your own proportioning.
The dual cylinder master effectively is what creates 2 separate brake systems, a front and a rear system complete with separate plumbing from the master to the paired calipers.
Old Mar 20, 2009 | 01:25 PM
wcsinx's Avatar
wcsinx
I think the proportioning valve/switch actually prevents that by blocking off the low pressure side in the event of a slave cylinder failure.
It's that alone which makes me leary of eliminating it though I know several guys that have.
Old Mar 20, 2009 | 02:18 PM
pauldana's Avatar
pauldana
I have replace the MC at least 3 times, the current one is NEW not rebuilt and 2 months old....
I heard that there is a peddle or rod adjustment, but I can not find or see any.. p
Old Mar 20, 2009 | 02:32 PM
noonie's Avatar
noonie
The properly working proportioning valve/pressure differential switch/combo valve, (is commonly misnamed) is not designed to separate the front and rear systems in case of failure. That is done with the master cylinder and the 2 separate circuits alone.
On some valves but not all, the spool can block off the failing side, but that is independant of the operating side. There should never be any fluid passage from front system to the rear system thru this valve.
that is why this is not correct.
……But what happens when the front seal goes out is the back seal is now being used to pressurize both lines……..
Old Mar 20, 2009 | 02:48 PM
noonie's Avatar
noonie
To test the mc installed on the car, remove the lines from mc, get some inverted flare plugs or make them out of welded up brake lines, and stand on the brake pedal. It should be very hard, stay there and be at the top. If not at the top, try and look under the dash and see how much rod movement there is before it engages.
I have never seen a rod bend from use, but anything is possible.
Old Mar 20, 2009 | 03:04 PM
GDaina's Avatar
GDaina
I am going to make this a sticky so no more bleed questions are asked.
For what it's worth...I start the bleeding process with air and then let the gravity take over....
Old Mar 20, 2009 | 03:31 PM
  #33
wcsinx's Avatar
wcsinx
It isolates failure to the front or rear in the case of a slave cylinder failure. But if the forward seal of the MC goes out, then yes you are pressurizing both lines with the rear seal. The 2 hydraulic circuits are no longer separated at that point.
You are however correct that there is no fluid passage front to rear through the valve. That was my misunderstanding.
Old Mar 20, 2009 | 04:00 PM
  #34
pauldana's Avatar
pauldana
So their is no way to adjust the rod?...
Old Mar 20, 2009 | 04:22 PM
  #35
wcsinx's Avatar
wcsinx
Not really
So replacing the MC had no effect on the pedal travel?
And this only happened after slamming on the brakes, right? I ask because excessive pedal travel can also be caused by mismatched boosters and MCs, but that would've been apparent immediately upon installation. Pull the MC off. You don't need to crack the hard lines, just take it loose and push it far enough away that you can see the booster output rod. Now get someone to sit in the driver's seat and push the brake pedal. As soon as they touch the pedal, you should see that rod move. If not, then we'll go from there.
Old Mar 20, 2009 | 04:39 PM
  #36
noonie's Avatar
noonie
NO....NO....NO
That valve has nothing to do with failure other than to power an idiot lite on the dash.
For the dual system operation take a look at this and pay particular attention to the parts that say
Primary failure and
Secondary failure
Also note that there are at least 1 additional seal(s) whose only purpose is separating the primary and secondary chambers in case of a failure of the other.
http://www.autoshop101.com/forms/brake02.pdf
Old Mar 20, 2009 | 04:42 PM
  #37
noonie's Avatar
noonie
There is no adjustment from booster to mc, but you can from pedal to booster, so make sure the mc is in the resting position and test for pedal engagement travel etc.
To bleeding the breaks... info please
Old Mar 20, 2009 | 04:58 PM
  #38
pauldana's Avatar
pauldana
YES pedal to booster.... but I have looked and see NOTHING to adjust. I have had the whole dash apart.... where is this secret adjustment? thx
Old Mar 20, 2009 | 08:58 PM
  #39
wcsinx's Avatar
wcsinx
NO....NO....NO
Absolutely incorrect, if a wheel cylinder leaks causing enough of a pressure differential between the front and rear circuits, then there's a piston inside that valve that gets pushed off center by the high pressure side into the low pressure side. This piston serves 2 purposes
1. To turn on the dash light
2. To shut off the low pressure circuit
This often causes difficulty in bleeding the brakes when people slam the pedal down, throw the piston off center, and then can't figure out why they're getting no flow to the front/rear.
Go read Tom454's post on the first page. He explained it quite well.
A good, properly functioning proportion valve (misnomer.. it's only a switch) will not allow you to bleed the brakes one line at a time. The principle of operation is such that when one line/caliper leaks (or is open for bleeding), hydraulic pressure (M/C-pedal pressure) will cause the valve's internal piston to slide to one side, activating the dash brake light, and closing off the opposite (front or rear) fluid circuit, rendering that closed off circuit un-bleedable. When this happens, the closed off half of the valve will allow little or no fluid to be bled through that circuit (front or rear).
Primary failure and
Secondary failure
Ok ... seriously, you do realize that's for a Lexus right and not a 30+ year old Corvette?
Here is a picture of the MC piston ...
Notice there are 2 and only 2 seals. If the front seal goes out, then you have lost the isolation of the front and rear circuits.
Old Mar 20, 2009 | 09:00 PM
  #40
wcsinx's Avatar
wcsinx
Again, if it were an adjustment issue, why did it only show up after a panic stop? I really think you're barking up the wrong tree here.
