Power Windows
Old Mar 18, 2009 | 04:35 PM
Fay vette's Avatar
Fay vette
Default Power Windows
Just got in and both windows will not work. Was working Sunday. Just seems dead like no power. Where to start? Where are the fuses?
Old Mar 18, 2009 | 04:42 PM
Fay vette's Avatar
Fay vette
Went back out, restarted it and they both worked down-up, then drivers side down then stopped. Now nothing again. Seem like loose wire somewhere. Where to start looking?
Old Mar 18, 2009 | 04:44 PM
spedaleden's Avatar
spedaleden
Grab a test light and check for power. Power windows use a circuit breaker. I've seen switches go bad. Check for power and ground at switches
Fuse box is located on left of steering column on firewall
Old Mar 18, 2009 | 04:57 PM
Fay vette's Avatar
Fay vette
Can I just take the side skirts off the center console or does the entire top have to come off to replace the switches. Divers switch seem "looser" than passingers. Can you still get these swithches at Auto Zone or do you need to order from a covette supplier?
Old Mar 18, 2009 | 05:31 PM
Shark Racer's Avatar
Shark Racer
My 78 'vette has had problems with the screw that holds the window relay in place backing out. That screw acts as a ground. If it backs out, you'll lose your capability to raise and lower 'em.
Old Mar 18, 2009 | 05:32 PM
Shark Racer
BTW -
If both are going out, it's most likely the relay or a fuse/breaker. Assuming this, if they're going out and coming back, then it's the relay.
If just ONE is going out, then check out that switch.
Old Mar 18, 2009 | 07:49 PM
spedaleden's Avatar
spedaleden
To replace switches the top needs to come off. I would disconnect battery then side shirts. a few side screws and the top will lift enought to remove two phillips screws to remove switch.
Try this: pushing to the up position and then to the down position and do this very fast for about 15 seconds. If the windows start to work or are inermittent replace the switch because it's going bad.
Does one window work and one doesn't? Usually drivers goes first.
Old Mar 18, 2009 | 10:53 PM
Fay vette's Avatar
Fay vette
Its either both work or both don't. Where is the relay located?
Old Mar 18, 2009 | 10:59 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Similar problem on my white79 was solved simply by removing the carpeted side panels, removing the switches and scraping the contact posts on the switches. They were slightly corroded. I could jiggle the connector a tiny bit and they would work. Seemed like corrosion on just one switch would affect both.
On another Vette, I had just the driver switch act up. Would go down easily but going up was hit or miss. Took the original switch apart and cleaned the copper leaves inside, Worked like new.
Old Mar 19, 2009 | 11:29 AM
Fay vette's Avatar
Fay vette
Gotta love the easy fix jobs. Wire was off the fuse box.
To Power Windows
