How much BackSpace is possible?
Old Mar 20, 2009 | 08:07 AM
Günther-C3's Avatar
Günther-C3
Default How much BackSpace is possible?
Hey guys!
What is the maximum of Backspace from a 18" diameter rim on stock trailing arms and stock front suspenison? 4"? 4,5?
Thanks, Günther
Old Mar 20, 2009 | 09:17 AM
GunPowder's Avatar
GunPowder
Günther,
I suggest also to include your picture (from the German Corvette web site) in order to explain what do you mean by "back space"
Old Mar 20, 2009 | 09:24 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I see you have a chrome bumper car, I have 4.5 BS on our 79 with 8.5 wide rims with no issues on stock trailing arms. Now the front might be an issue with rubbing with full turn on your bumper car.
Old Mar 20, 2009 | 05:32 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Hallo Guenther!
Ich glaube das mit der originalen radaufhaengung, wuerde ich sagen das Du hinten 4.5 " backspacing und vorne 4 " backspacing verwenden kannst.
Uebrigens, schoene Gruesse nach Oesterreich! Ich bin gebuertiger Oesterreicher, bin allerdings schon 12 Jahre in Florida und inzwischen Amerikaner!!
Old Mar 20, 2009 | 05:54 PM
roscobbc's Avatar
roscobbc
Originally Posted by Günther-C3
Hey guys!
Thanks, Günther
On '68 I have 5" backspace on rear with 18 X 9 rims and stock trailing arms. With 285/40/18 it gets very close but dosen't touch - parking brake cable is another matter. Front is 4" backspace and 18 x 8 rim with 245/45/18 - contact issues here! driver side, tyre slightly on inside of chassis rail - passenger side bottom rear of fender opening, this on my car needed sectioning for clearance!
Old Mar 20, 2009 | 06:13 PM
Solid LT1's Avatar
Solid LT1
5 inches on rear IF you move brake cable bracket to top of the trailing arm.
Old Mar 20, 2009 | 07:20 PM
Gordonm's Avatar
Gordonm
I have an 18X10 with a 5.5 backspace on the rear on stock trailing arms. I did move the ebrake cable but that is it. No rubbing with 275 40 18 tires.
Old Mar 20, 2009 | 07:34 PM
MOS11C's Avatar
MOS11C
Originally Posted by GrandSportC3
Hallo Guenther!
wo lebten Sie vor Ihren 12 Jahren in Florida?
Old Mar 20, 2009 | 08:11 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
CF'er Bee Jay has just put a set of 295/35's & 18 x 10.5's C5 Z06 wheels on his C3 w/2.5" adapters, but he's getting some 2" adapters, as they're likely to hit the outer fender opening as they are. If it works, and my calculations are correct, that works out to 5.9" BS. FWIW, he does have offset TA's.
http://forums.corvetteforum.com/c3-t...ls-are-on.html
TSW
Old Mar 20, 2009 | 08:56 PM
3JsVette's Avatar
3JsVette
I'm pretty sure that past 5.5" of backspace with 18" wheels in the rear the frame becomes the limiting factor not the trailing arm. Check with Gordonm on that one to be sure. In the front with VB&P tubular arms for the mono spring set up you can get away with 4.5" of backspace. I know that's what Chris McDonald was running on his black '69 vert "Killer Shark".
Old Mar 20, 2009 | 09:40 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I've got 5 inch on my 18's and the wheel and tire are just flush with fender with 9.5" rim. I believe you can fit 5.5 inch but that might change from year to year or Vette to Vette
To How much BackSpace is possible?
