82 High Idle
Old Mar 23, 2009 | 08:22 AM
gevans's Avatar
gevans
Default 82 High Idle
My wife's 82 has an extremely high idle (2k) when she starts it up. After warming up for a minute or two, the idle does not go down. In gear while stopped, the idle is fine. After driving around town a bit, placing transmission in park, idle is fine. What could be causing the excessive high idle during first start? Thanks!
Old Mar 23, 2009 | 08:37 AM
jdp6000's Avatar
jdp6000
Probably a bad coolant Temp Sensor. Its at the front of the engine just below where the thermostat housing is. Easy and cheap to replace.Make sure the rad is full too.
Jim
Old Mar 23, 2009 | 08:47 AM
JimT's Avatar
JimT
Once warm, and car idle is still high, tap the gas pedal. If the idle drops you may have a sticky choke valve.
Old Mar 23, 2009 | 09:04 AM
jdp6000's Avatar
jdp6000
No choke valve on a 1982. CTS,MAP and ECM control idle when cold.
Jim
Old Mar 23, 2009 | 09:06 AM
gevans's Avatar
gevans
I will check the temp sensor and coolant level! However, the water temp sensor on gauge reads in the normal range.
Quick tap on accelator does not make idle go down
Thanks!
Old Mar 23, 2009 | 09:18 AM
jdp6000's Avatar
jdp6000
Thanks!
The CTS and temp sensor for the gauge are different sensors. The CTS communicates with the ECM (computer). The temperature sensor is on the side of the block and communicates with the gauge.
The coolant level is important in the 82 because if its low the water does not touch the tip of the CTS sensor. So the sensor is just reading air in there at the beginning. Once the car warms and the thermostat opens water rushes by the CTS and a reading is taken.
If you have been under the hood lately also make sure you didn't knock a vac hose of somewhere.
Jim
Old Mar 23, 2009 | 01:17 PM
MN-Brent's Avatar
MN-Brent
Sound like the CTS is starting to change-fail. It does this gradually as it shifts the resistance reading it gives back to your ECM.
Change it, its cheap, and I'm sure youll notice a diference.
Mine was doing the same thing as yours. Symptoms worse on cooler days than wamrer days. Replacing the CTS took care of it.
Old Mar 23, 2009 | 02:06 PM
gevans's Avatar
gevans
Thanks MN! Will do! That is just below the thermostat housing right?
Old Mar 23, 2009 | 02:11 PM
jdp6000's Avatar
jdp6000
You will see a couple of wires going to it. Yes infront ot the "Tstat" and a bit lower.
Jim
To 82 High Idle
