carb help
Old Mar 23, 2009 | 10:07 AM
2TS-73's Avatar
2TS-73
Default carb help
i have a holley q jet relacement carb #9895 that i bought and was told that it had been rebuilt, when i start it up the car is running rich,and when i shut off the car gas comes out inside the back two barrels near the bottom, i took the back off and made sure the float was not set to high and also made sure the back two barrels were not sticking open, could i have a bad needle and seat causing this, they look new?
Old Mar 23, 2009 | 10:57 AM
gerry72's Avatar
gerry72
Fuel dripping out of the booster under idle is a very good sign the fuel level is too high in the bowl. It could be the float adjustment, a dirty or bad needle and seat, a bad seal on the seat(many omit the ring seal), dirt in the needle and seat, a slightly sunken float.
