Give me a BRAKE
I'm confident my spongyness came from leaky calipers and I should expect some extra firmness going from rubber to steel-braided lines at the wheels, but it just does not feel right. The master-cyl is not very old which is why it wasn't replaced and I'm pretty good with brakes, so I doubt I did anything wrong at the wheels. The two things I've never dealt with is the booster and proportioning valve. I didn't touch the valve during the replacement process, so I'm thinking booster. It's new and when I take the vacuum line off of it, my engine nearly dies, so I know there is at least some vacuum.
Does anyone know other types of tests I can perform to get more pressure to the wheels? i.e. specific vacuum required for the booster?
I had to go around at least 3 times to get a good pedal
Jim
Regardless, I'll go around it a couple more times after checking for vacuum (thank you for that measurement). Shoot, I just thought of something...
My replacement calipers have "3" bleeders. While mounted on the car, 1 (inner I think) is at the top with 2 (inner and outer) at the bottom of the caliper. I believe I did inner and then outer. Is that right?
Pedal is hard to push & take a lot of effort to stop? Make sure you have sufficient vacuum at the booster and no vacuum leaks. Check your vacuum readings while stepping on the pedal also & listen for a hissing noise under the dash indicating a vacuum leak. Lost a booster on my Mustang once while stopping at an intersecting. Car stalled, no brakes, went right through the stop sign.
Luckily no one was coming. Went right home & changed my shorts
