l-88 hood question
Old Mar 23, 2009 | 09:31 PM
bondoboy's Avatar
bondoboy
Default l-88 hood question
I am considering putting an l-88 hood with the cold air box on my 71. How exactly do you get a good seal on the air filter when it lays inside the hood? I have never seen this setup up close, so maybe I am missing something. Thank you.
Old Mar 23, 2009 | 10:09 PM
myk7's Avatar
myk7
The lower part of the air filter assembly stays on the carb. It has a seal on it that seals with the hood when the hood is closed. The filter is in the hood.
Old Mar 23, 2009 | 10:13 PM
spookytooth's Avatar
spookytooth
I have the L-88 hood on my 72, I currently use the foam filter in the hood. I would like to upgrade to a better filter element. Have others done this and what have they used?
Old Mar 23, 2009 | 11:52 PM
OzzyTom's Avatar
OzzyTom
proper L88 air intake setup above.
And the air cleaner is located in a moulding in the bonnet as shown below.
Old Mar 24, 2009 | 05:31 AM
bondoboy's Avatar
bondoboy
Thanks for the help. I knew the base stayed on the carb, I was wondering what seals the filter to the hood. What keeps dirt from going over the top of the filter?
Old Mar 24, 2009 | 07:39 AM
OzzyTom's Avatar
OzzyTom
The filter sits in the sealed air chamber section shown in the second photo.
It's not clear in the photo, but the air filter is sealed up against the underside of the hood as well as the recessed circular base of the air chamber.
It is sealed so that air can only enter the carb through the filter element when the bonnet is shut.
Old Mar 24, 2009 | 04:58 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I have a 3" K&N filter in my L-88 hood. I used the original L-88 style foam filter cut down to about 1" thick to seal the areas where the K&N was a little loose. In this pic, you can see the squished down portion of the original foam filter holding the K&N in:
Old Mar 25, 2009 | 11:54 PM
Snowman's Avatar
Snowman
CI 1-2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '03-'04-'05-'06-'07-'08-'09
Very sweet setup. How many thousand tries did it take to line everything up correctly? What was the secret?
Doug
Old Mar 27, 2009 | 09:15 PM
bondoboy's Avatar
bondoboy
To l-88 hood question
