Inner door panel
Old Mar 24, 2009 | 11:49 AM
AvRog's Avatar
AvRog
Default Inner door panel
How do I remove the window crank handle to remove the inner door panel. The AIM is of no help.
Thanks, Roger.
Old Mar 24, 2009 | 12:02 PM
midlife69's Avatar
midlife69
St. Jude Donor '09
Roger, there is a small clip you need to remove. You can remove it with a hooked dental type pick or a wire hanger with a short bend in the end of it. They also make a special tool you can buy at the auto parts store that works pretty good. I just went through getting mine off and the biggest trick is to know where you can grab the clip, or push it if you get the special tool. On mine at least the clip will either face at the window crank **** or away from it depending on how it was installed. I hope this helps a little.
Old Mar 24, 2009 | 12:47 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
The opening of the clip is SUPPOSED to face the handle. That said, one of mine was on that way and the other was on backwards. Pretty much all Ford and GM cars from the 60s and 70s used these "Jesus clips", so the tool for it is usually available at NAPA. The tool I bought worked like a charm on the window cranks, but didn't work on the lock *****. To get those, I fashioned a little hook from a stiff paper clip and grabbed them. It really wasn't bad at all.
Old Mar 24, 2009 | 12:56 PM
AvRog's Avatar
AvRog
Thanks dudes, Thats what I needed to know!
Later, Rog.
Old Mar 24, 2009 | 01:15 PM
AvRog's Avatar
AvRog
I'm about to get into my doors to change the locks and align the windows.Any words of wisdom or posts you think I should read?
Later, Rog.
Old Mar 24, 2009 | 01:16 PM
57charley's Avatar
57charley
Made my own tool, I took an old can opener, the kind that makes a triangle shaped hole in the edge of the can, and bent the tip of it up about 90 degrees and 1/16 inch high.
Old Mar 25, 2009 | 08:53 AM
AvRog's Avatar
AvRog
Thanks 57
To Inner door panel
