Valves ticking- underadjusted?
Old Mar 24, 2009 | 01:54 PM
kunkle's Avatar
kunkle
Default Valves ticking- underadjusted?
Hi all,
Getting some valvetrain noise in my new engine I just built. Just tightened the headers so I know it's not that. Sounds great when I start it cold, I get the noise on both sides after it's warm. It's a Comp hydraulic roller cam. I adjusted them 1/2 turn past zero lash like the Comp instructions say, but the old instructions from the Crane roller lifters that are in there say 1/2 to 1 turn past zero lash.
It's not very loud, can only hear it over the engine bay.
Should I just give them all another 1/2 turn and see if the noise goes away? Comp instructions say insufficient preload will cause noise as opposed to over tight. Thanks.
Old Mar 24, 2009 | 02:20 PM
QuicheLorraine's Avatar
QuicheLorraine
I think that roller valve trains will always have some type of a regular tick.
Old Mar 24, 2009 | 02:45 PM
WillEE's Avatar
WillEE
1. I wouldn't agree that the roller cams always having a tick is necessarily an explanation for what you're describing.
2. Would not go around and tighten 1/2 more on each adjuster w/o veriftying that they are adjusted properly in the first place.
3. I would highly recommend contacting Comp Cams and discussing the proper adjustment procedure for your cam and make sure you have it well understood before proceeding. 1 full turn sounds excessive to me. I would then go around and verify that each one is adjusted properly. It will take some time but will be worth it. You want to make sure you're valves are operating right for performance and also so doesn't result in damage or premature wear and tear.
4. Make sure you torqued the rocker studs to proper torque and they are not loosening up on you which will get real ugly fast if not tended to.
Old Mar 24, 2009 | 02:51 PM
WillEE's Avatar
WillEE
One other thought - you may want to double check it's not headers first (assuming your confident the valves were adjusted properly). You said you tightened the header bolts but were they loose and could they have possibly blown through a gasket which can happen quickly once they become loose. Sometimes it's very hard to tell. I like to take a moist rag and wear a leather glove and move it around the tubes to see if muffles a leak/ticking sound.
Old Mar 24, 2009 | 03:25 PM
midyearvette's Avatar
midyearvette
Originally Posted by kunkle
Hi all,
aluminum heads??
Old Mar 25, 2009 | 01:57 PM
kunkle's Avatar
kunkle
Called Comp and they basically said the little bit of noise I'm getting is normal given the cam and roller tipped rockers. Thanks.
Dave Kunkle
To Valves ticking- underadjusted?
