77 fuel gauge problem
Old Mar 24, 2009 | 07:56 PM
mds3013's Avatar
mds3013
Default 77 fuel gauge problem
77 fuel gauge shows 1/4 full when tank is full. when I disconnect fuel sending unit at wiring connector behind left rear wheel, gauge goes to past full. I have hooked up another sending unit at wiring connector and it shows same reading when float at tank full position. Ohm readings from both sending units are the same that Wilcox quotes as correct. What am I missing? Thanks in advance mds...
Old Mar 24, 2009 | 11:03 PM
KGKVette's Avatar
KGKVette
You may want to check the ohm reading on the blue - ceramic piece between the power and signal leads. My 79 which should be the same for 77 is 90 ohm.
