Patriot Lake sidepipe install..help?
Old Mar 24, 2009 | 11:01 PM
dmeesq's Avatar
dmeesq
Default Patriot Lake sidepipe install..help?
Does anyone have pics and or diagram on how to install patriot lake sidepipes, any help would be greatly appreciated, just how to hook the pipes to the car, hooking them to my headers in no prob. Ordered a set, just wanted the info before they got here.
Old Mar 24, 2009 | 11:40 PM
Buzzardz_vette's Avatar
Buzzardz_vette
Old Mar 25, 2009 | 01:49 PM
stingraymaniac's Avatar
stingraymaniac
I have them on mine and you get the mounting brackets with the pipes.
I took of the rocker moldings and drilled two holes in the frame and then tapped them.
but measure first so you get them so close you can to the molding..
i needed to cut the molding a bit to get them as close as i wanted.
they are now almost against the molding but they do not touch
They have been on now for 4 years and they havent moved,just get some sealant on between the sidepipe and header before you push them together
Old Mar 25, 2009 | 02:19 PM
Buzzardz_vette
Can you post a pic of the actual mounting bracket and how its attached to the frame? Thanks.
Old Mar 25, 2009 | 03:37 PM
dmeesq's Avatar
dmeesq
bump
Old Mar 25, 2009 | 03:41 PM
Saint's Shark's Avatar
Saint's Shark
Wow stingraymaniac - from that first picture it seems as though there's not a lot of ground clearance. Is it just the picture angle that looks deceiving?
Old Mar 25, 2009 | 04:33 PM
stingraymaniac
Ground clearance is fine theres alot of speed bumps around here and i havent had any problems.
The pipes are at the same heigh as the frame on the sides,i have lowered the car pretty much also..
I think the are at the same height as a pair of hookers because the headers are almost against the frame
The car is in vinter storage right now 30 miles from here,but i can get pics the next time im there
Old Mar 25, 2009 | 04:48 PM
dmeesq's Avatar
dmeesq
ttt
Old Mar 25, 2009 | 06:09 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
I made my own brackets to mount them to the frame. I did drill and tap the frame as described above. I used 2 bolts per bracket. I have mine a bit further away from the rocker than shown above. I did not want the rockers getting too hot. My car was a factory sidepipe car so the insulation was already on the frame under the door. These pics are the best I can do without removing the rockers. Hope this helps.
Old Mar 25, 2009 | 06:33 PM
oram's Avatar
oram
not trying to hijack this thread .... i'm interested in installing side pipes on my 74 vette ... you mentioned the frame under your doors are already insulated ....... how would i insulate or do i have to insulate before installing side pipes... i apologize if i was suppose to start a new thread ...
Old Mar 25, 2009 | 07:42 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
When you ordered the N-14 option for sidepipes you got several differences with that option. One of them was the additional fiberglass backed with foil insulation along the frame rail to prevent excess heat from transfering into the cabin. I guess nobody installing side pipes either Patriot or Hooker bothers to add this insulation during their install.
To Patriot Lake sidepipe install..help?
