My Latest Odd-Stupid Question
Old Mar 26, 2009 | 03:08 PM
doug.storch's Avatar
doug.storch
Default My Latest Odd-Stupid Question
Without getting into a big discusssion on the pros and cons of drilled and slotted brake rotors I need to ask about orientation. Not sure how to ask but should the hole pattern/slots be like a saw blade (on the upperside of the rotor the slots would be pointing towards the front of the car) or the other way around? Does anyone actually understand what I am asking?
Old Mar 26, 2009 | 03:19 PM
2armor's Avatar
2armor
I just installed vbp's double ball milled rotors and their diagram for mounting showed the leading (inner) edge forward of the outer trailing edge of the groove. You basicly want the hot gases to vent to the outside of the rotor as it turns, not pushed towards the hub/bearings. I presume rotors with holes would be the same..
If the groove on the drivers side rotor is at 12 o'clock it should be like this = /
is that what ur asking?
Old Mar 26, 2009 | 03:48 PM
doug.storch
Default Thats It!
Thats exactly what I was asking; excellent description of the orientation. Makes sense too. That is what I always thought but some car buddies were trying to convince me they should go the other way (perhaps they meant themselves, not the rotors ).
Thanks !
Old Mar 26, 2009 | 05:47 PM
Mike Ward's Avatar
Mike Ward
It's makes no difference in operation. The slots do nothing anyway except reduce friction surface.
Old Mar 26, 2009 | 05:54 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
But they look good!
For normal driving I agree. But for autocrossing etc where your hot on the brakes the venting can add some value. My opinion anyway.
...and they look good!
Old Mar 26, 2009 | 06:01 PM
straub18045's Avatar
straub18045
slots help expell gases produced from extreme heat and friction
Old Mar 26, 2009 | 09:28 PM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
Just fyi, check drilled rotors in a search, you won't find any of the road racers running drilled or slotted rotors, they concentrate heat and provide weak spots and pathways for cracking. Drilled rotor provide no benefits and fail or fall apart under heavy use....they do look kinda cool though
Old Mar 26, 2009 | 09:35 PM
GUSTO14's Avatar
GUSTO14
The slots in the face of the rotor are of little importance regarding how to mount them. Different manufactures orient them differently. What does matter is the orientation of the cooling vanes inside the rotor.
The vanes should be oriented so that they expel air as they rotate. If the vanes are oriented axially (straight from the hub to the perimeter, like spokes in a wagon wheel) then mount the rotors to suit your preference. If the vanes are angled from the hub to the perimeter of the rotor, the rotor should be mounted so that the vanes point to the rear of the car at the top and the front of the car at the bottom. As the car moves forward, the air will be drawn in at the hub and expelled at the outer edge of the rotor.
Good luck... GUSTO
Old Mar 26, 2009 | 09:43 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Good luck... GUSTO
Right! I got drilled and slotted since my car is all show and no go. Here are a couple pictures of the 2009 corvette rotors.
Old Mar 27, 2009 | 12:14 PM
2armor's Avatar
2armor
Guess nobody read that part..
Lets talk about oil now
Old Mar 27, 2009 | 12:32 PM
63mako's Avatar
63mako
Right.
Old Mar 27, 2009 | 01:06 PM
doug.storch
I tried.
Really I tried
Old Mar 27, 2009 | 02:14 PM
63mako's Avatar
63mako
At least you got your question answered.
http://www.zeckhausen.com/how_to_pro...all_rotors.htm
Old Mar 27, 2009 | 05:21 PM
Mike Ward's Avatar
Mike Ward
I tried.
Really I tried
You would have gotten the same response if you had asked any subjective question, with or without the please to not start a debate.
Tastes great or less filling? Talk amongst yourselves.
Old Mar 28, 2009 | 08:16 AM
73-84 IMSA Widebody
My bad....selective reading
Old Mar 28, 2009 | 11:54 AM
babbah's Avatar
babbah
Originally Posted by dosoctaves
But they look good!
Old Mar 28, 2009 | 04:26 PM
Bowerss2's Avatar
Bowerss2
ok i will bite,
the z06 rotor is for show
that carbon ZR1 rotor is a different story, outgassing is a problem with the rotors themselves.
also, some race teams do it for driving in the wet, so the steam can escape.... mostly it looks cool though
Old Mar 28, 2009 | 04:27 PM
Bowerss2's Avatar
Bowerss2
I tried.
Really I tried
hahaha sorry bro, you bring up Brakes, ZDDP, Oil, and you are asking for it hahah
To My Latest Odd-Stupid Question
