solid lifter valve lash settings
Old Mar 26, 2009 | 05:37 PM
dmayhew's Avatar
dmayhew
Default solid lifter valve lash settings
I started and ran my 350 motor Tuesday to breakin the new solid lifter cam. Ran the motor for just over 30 minutes between 2000 and 2500 RPM's. Used Joe Gibbs BR oil / Primed the oil pump / filled float bowl manually before starting.
The motor fired right a way and ran great. Was able to get to 2000 RPM right a way.
All went well when finished so far knock on wood! , the sound at idle was very nice at the exhaust.
I had the lash set at +.002 for a cold start per instrunctions.
int .022 cold Hot is .020
ex. .027 cold Hot is .025
I have not had a chance yet to set them at normal operating temp.
I like the sould of the chatter from solid lifters. Comp Cams said I can adjust as much as + or - .004 from the cam card setting.
Question is
If I set at .022 on Intake HOT and .027 Exhaust HOT
I feel I will get a more noticable chatter , thats ok with me.
But what performance gains or losses will this cause if any?
Are there any reasons to not set them a little losser just to get a little more chatter??
David
Old Mar 26, 2009 | 06:58 PM
midyearvette's Avatar
midyearvette
you do not want too much lash or chatter......004 is not enough to matter.......too much lash is extra hard wear on the valve train......
Old Mar 26, 2009 | 07:10 PM
Ganey's Avatar
Ganey
Increasing lash reduces lift & therefore reduces perf.
Old Mar 26, 2009 | 07:17 PM
dmayhew's Avatar
dmayhew
Thanks to both of you
I think the advise is sound and makes sense to me.
I will stick with the cam card recomendations
David
Old Mar 26, 2009 | 07:25 PM
VictoriaVette's Avatar
VictoriaVette
I built a 355 solid lift engine and when to go + or - on the valve adjustment it does not mean reduced performance. The best I can remember tight gives you my bottom end and lose give you more top end.
Old Mar 26, 2009 | 07:59 PM
Ganey's Avatar
Ganey
The other way around- tight for higher HP. Loose would be expected to reduce max. HP. This could increase low rpm torque so depending on the setup, it could result in better perf. at lower rpms.
Old Mar 26, 2009 | 08:07 PM
VictoriaVette
Thnaks for the correction I knew it was a difference been many years since I had that solid lift set up. It did make a difference.
Old Mar 26, 2009 | 10:45 PM
Retro78's Avatar
Retro78
Are you running aluminum heads? If yes you went in the wrong direction and are running way to much lash.
You may like the sound of a lot of lash, but you are beating the crap out of your valve train.
Old Mar 27, 2009 | 07:33 AM
pws69's Avatar
pws69
Based on actual experience, I respectfully disagree. Running valves a tad looser than specs definitely increases performance.
Old Mar 27, 2009 | 07:57 AM
midyearvette
respectfully, if that is your experience.....you had way too much camshaft!!.....
Old Mar 27, 2009 | 09:01 AM
pws69's Avatar
pws69
ooookay.....
Old Mar 27, 2009 | 02:14 PM
dmayhew's Avatar
dmayhew
I am not running Aluminum heads , I think you advice would have been better given after I answered your question , If I did have aluminum heads , but I do not
Iron Block Iron Heads / +.002 on cold startup
David
To solid lifter valve lash settings
