80 corvette polution a.i.r. removal
Old Mar 27, 2009 | 10:09 AM
dfcvett's Avatar
dfcvett
Default 80 corvette polution a.i.r. removal
What do I do to remove all polution controls on my 80 vett?
Old Mar 27, 2009 | 10:40 AM
Darrel1's Avatar
Darrel1
I just took off the AIR compressor, EGR valve and the switches that go into the T-stat housing. I plugged the holes with brass pipe fittings and then created a metal plate to cover the EGR valve holes. I also removed the "spider lines that go into the exhaust manifold and just plugged those with brass fittings. The valve that is between the manifold and pipe (forgot the name) is still there in open postion- I think there is a spacer pipe that you need to buy if you remove that hardware.
Darrel1
Old Mar 27, 2009 | 10:46 AM
PhyscoVette's Avatar
PhyscoVette
I oretty much did the same as mentioned above, except that I have headers and true duel exhaust added to the no smog list. sure freed up a bunch of wasted Hp
To 80 corvette polution a.i.r. removal
