Quadra-Jet Restoration And Modification
http://www.valvoline.com/carcare/art...cid=5&scccid=5
http://www.valvoline.com/carcare/tip...es&tipNumber=2
God bless, Sensei
God bless, Sensei
or you could just send it to this guy and get a good job done!It all sounds complicated, but once you start tearing it apart, you understand what things are and what they do pretty quick.
Sean
"Carb Shop" for rebuild. This was a few years ago, but it cost about
$250. After that it was like FI. I would pump the gas twice and it started. I had them sort out my Demon reciently, very happy w/results.
If you have to pass smog, get a pro built q jet. JMHO
Ricisan
1) Mal-functioning accelerator pump. To check, take the air cleaner lid off and look down the primary (small) barrels. As you look, pull the throttle linkage. You should see two strong, squirt gun like streams of gas shoot into the barrels. If the streams are weak, sputtering or non-existant, your pump needs repair. It is easy to fix, but if the carb has never been rebuilt, you might as well get the kit (which contains the pump plunger) and go through the entire carb.
2) Mal-adjusted secondary air valve (air valve is the butterfly over the secondaries). To adjust, find the small flat head adjusting screw on the passenger side end of the air valve shaft and the allen head screw coming up underneth it at 90 degrees (use a mirror to find the allen head screw). Loosen the allen head screw to allow the flat head srew to turn, then loosen the flat head screw until you see the spring on the airvalve shaft (use the mirror) loose contact with its tang, then re-tighten it 7/8 turn past the point at which the spring contacts the tang.
Between these two, you will probably find the fix. The second one is free and easy to fix. the first one is still not too bad to take care of. Bad news is, I would guess, if the pump plunger was the original that came on the car, the ethanol in the fuels these days did it in. The good news is, you can get plungers for the pumps now that are not damaged by ethanol.
God bless, Sensei
The secondary air valve spring a1sensei mentioned is only for closing the air valves. As he said it must be adjusted correctly. The spring does not control the opening rate. That is controlled by the choke pull-off. If the pull-off is bad you will have a secondary bog.
Mike
