1970 Brake Question
Old Mar 30, 2009 | 04:58 PM
midlifemuscle's Avatar
midlifemuscle
Default 1970 Brake Question
I've just installed remanufactured brake calipers on all 4 wheels and completely bled the system. The car pulls to the right somewhat on braking and returns to center when I release the brakes. Any ideas on what's wrong would be appreciated.
Old Mar 30, 2009 | 05:09 PM
wer2xu's Avatar
wer2xu
did you have the rotors turned, or install new ones?
Old Mar 30, 2009 | 06:28 PM
KevinK's Avatar
KevinK
Could be any number of things....
Did you bleed the brakes yourself, and if so, are you SURE there is no fluid left on the disk?
And as stated above, did you stick with the same disks, and if so, did you turn them, cut them, etc?
Old Mar 30, 2009 | 06:41 PM
Duke94's Avatar
Duke94
Did you replace the front rubber hoses? If they are old, they may have come apart on the inside and caused a flow restriction. Could also be some type of suspension/steering issue. Did it pull before you changed the calipers?
Gary
Old Apr 1, 2009 | 05:00 PM
midlifemuscle
I did not turn the rotors, although I did check for excessive runout - they were ok.
Old Apr 1, 2009 | 05:01 PM
midlifemuscle
I did not get any fluid on the rotors and did not turn the rotors. I did check them for excessive runout and they are ok.
Old Apr 2, 2009 | 10:19 AM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
Bleed the brakes one more time. You can do the "loan a tool" program and get a vacuum bleeder, which does a great job of flushing the system.
If you have not completely flushed the brake fluid, you need to. buy a big bottle of brake fluid and suck out all the old fluid until it runs clear.
You can typically tell if there is a restriction in the line with the vacuum bleeder.
If you don't find a restriction and don't find any air, and still have the pull on braking, have the car aligned. Sometimes alignment issues are not noticeable unless you are under hard braking. It could even be a bad shock.
Good luck and be sure to post what you finally determine what the problem is.
Old Apr 2, 2009 | 12:18 PM
midlifemuscle
Thanks! I bled everything again (the conventional way) and everything's now working properly. By the way, I had already purged out all of the old fluid, but thanks for the tip anyway.
To 1970 Brake Question
