Serpentine Pulley Conversion, anybody done it
Old Jan 30, 2002 | 12:53 AM
john73bb's Avatar
john73bb
Default Serpentine Pulley Conversion, anybody done it
Has anyone done a conversion without using a system like March or other "off the shelf" system. Here's the obvious things I know need to be done:
Reverse flow water pump
Idler mounting bracket and idler pulley (junk yard)
Pulleys for A/CC (need newer compressor?), Alternator (easy I presume), Power Steering (should be available), Crank (should be readily available)
Belt -- have to find one close and take up the slack with the idler
I have an electric fan system so I don't need to worry about that getting in the way.
Are there sources (inexpensive of course) for pulleys? can my old 73 style A/C compressor be converted? Or will I need to go with a more modern compressor?
Any thoughts?
John.
Old Jan 30, 2002 | 01:18 AM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Serpentine Pulley Conversion, anybody done it (john73bb)
Yep, Budman 78 has, look him up :yesnod:
Old Jan 30, 2002 | 01:33 AM
mrvette's Avatar
mrvette
Yes, use a stock '88 vette-up setup....and the older alternator fits with minor mods....airpump elim from Breathless Perf. is recommended....
the late comperssor works fine with earlier systems....
MAY need custom hoses though, probably not....unless you have that R4 junky compressor.....the older A6 type hoses should bolt up though...
GENE
Old Jan 30, 2002 | 01:47 AM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Default Re: Serpentine Pulley Conversion, anybody done it (mrvette)
mrvette,
An 88 ac compressor will hook up without new hoses? And it's a good compressor?
Old Jan 30, 2002 | 01:50 AM
john73bb's Avatar
john73bb
I have the old, long compressor with the bolt in the back of it to pivot on. The one that makes changing spark plugs (the front 2) a real pain.
Converting to the newer one would probably be OK, since I am going to have to remove the old one since it has gone bad. I doubt NAPA will trade for the newer one on warranty, but I can try. My alternator is out of a Fleetwood (to get higher current) so getting a pulley for it should be as easy as going to the junk yard and removing one. How about the power steering pump? It has the big cast double V pulley on it now, can I find a pulley for it or will I have to make one?
Old Jan 30, 2002 | 07:50 AM
mrvette's Avatar
mrvette
IF you use a stock '88 up vette system, you need a reverse rotation water and steering pumps.......as they ride on the 'backside' of the belt....
now using another style system from an aftermarket source will probably be much more expensive....
I would use the stock setup, as its all bolt on and forgetaboutit.....
yes the '88 compressor style is a good one, works fine....I had to get custom hoses made, because my original hoses were trash....
but the style is so very close, and I know the compressor ends will work...
GENE
Old Jan 30, 2002 | 08:34 AM
Anar76's Avatar
Anar76
Why would you want to reverse the direction ?
Is there any advantages I don't know about ?
Old Jan 30, 2002 | 08:42 AM
mrvette's Avatar
mrvette
Default Re: Serpentine Pulley Conversion, anybody done it (Anar76)
It not that reversing rotation direction of the pumps make any differance in end product performance, it's the routing of the stock serp belt in thost era cars....
When I first looked into a serp conversion for my '72 SB, I discovered that 5-6 years ago anyway, most all aftermarket suppliers would NOT guarantee their systems to fit any specific car, so I remembered my '87, looked at '88 up systems in club members cars, and figgered they would fit,....it did......
so go to a vette junkyard and get the front end off a newer vette, should work fine....L98 that, is....I dunno/not sure about LT1 setup....I forget....
GENE
Old Jan 30, 2002 | 10:11 AM
john73bb's Avatar
john73bb
Does this apply to big blocks too?
Old Jan 30, 2002 | 10:20 AM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Budman told me that a good source for complete serpentine systems is from Chevy/GM pickups. I've looked at my 94 pickup and it looks like it would be a no brainer to swap the stuff to the 'vette. Of course you'd have to verify water-pump and P/S rotation and make the appropriate changes.
I haven't checked with wrecking yards for availability of complete setups, but I bet it would be a small fraction of a March setup. It won't look as good, but it should work the same way.
Old Jan 30, 2002 | 10:38 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
Default Re: Serpentine Pulley Conversion, anybody done it (Smokehouse69)
I'm not sure Big blocks are the same. I think March or S & P are the only sources for it, unless there is a late model truck with a big block. Maybe one of those SS454 trucks. I would go to the dealership and look at the detail sheets in parts.
As far as the conversion, it should be a no brainer. The later model PS pumps work great with the older racks. I only had to make on hose and it only set me back $15.00. I mounted the researve on the crossmember with a fabricated bracket. The most expensive part was a polished tensioner from S & P for the alt.
Good Luck
Old Jan 30, 2002 | 10:42 AM
john73bb's Avatar
john73bb
Default Re: Serpentine Pulley Conversion, anybody done it (Budman78)
Thanks for all the help.
Looks like I should be able to do the conversion then. I'll start frequenting the local shopping centers (u-pull-it junk yards :lol:) looking for parts. I'll post how it went when I'm done.
Old Jan 30, 2002 | 11:19 AM
fauxrs's Avatar
fauxrs
Pace Chevy now sells a kit for this - I do not know about its specific applicability to vettes but you might contact them.
They have picts of the system on their web page
from their web page:
This deluxe serpentine belt drive system with air conditioner includes all the components to install on small-block Chevrolet engines. The bolts, nuts spacers and braces are included with the following major items: 10055800 Secondary Air Injector pump bracket, 1134344 Air compressor assembly, 10129569 Idler belt pulley bracket, 88894005 Water pump kit, 10055880 Water pump pully, 10055879 Crankshaft pulley, 10463172 Generator assembly, 12117361 Generator connector, 10055798 Drive Belt Tensioner Assembly, 10085752 Belt, 10105212 Generator & power stearin bracket, 26010328 Power steering pump, 14102096 Power steering pulley..
http://paceparts.com/
Old Jan 30, 2002 | 12:41 PM
john73bb's Avatar
john73bb
Default Re: Serpentine Pulley Conversion, anybody done it (fauxrs)
It's for a small block. Parts of it might fit my car, but I don't wan't to pay that and then find it doesn't. I may call them.
Half the fun of working on these beasts is the "figuring out how to do it" part. I will try to build my own and then when I fail I will spend the money to buy a setup, or I will decide v-belts are really not that bad after all :) .
Old Jan 30, 2002 | 01:34 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Check this site out. http://www.ss454.com
Loads of pics of SS454 Trucks engines with the Serpentine belt systems. It also looks line the A/C and the Alt are on the right side.
Old Jan 30, 2002 | 02:46 PM
john73bb's Avatar
john73bb
Those guys are as crazy as corvette owners.
Yes, they do have similar configurations - although they are not nearly as space constrained. It looks like they are using the same PS pump as we have on our cars. I guess if they work they work. So, I should be able to find pulleys for it pretty easily. I will probably need to change out the A/C compressor though :( That looks like some work, and some more money.
Old Jan 30, 2002 | 03:21 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
A sepentine air compressor is $99 at AutoZone. Recharging is another story.
To Serpentine Pulley Conversion, anybody done it
Old Jan 30, 2002 | 03:29 PM
Flareside's Avatar
Flareside
Guys, I believe that truck engine is using a long water pump. If it is, it won't fit in a Vette. You would need to move everything, including the compressor, forward. I don't think it will physically fit without major work.
Check out the stuff from Zoops. http://www.zoops.com I'm going with their short pump serpentine setup and the smaller, more modern power steering pump.
-Joe
Old Jan 30, 2002 | 03:59 PM
john73bb's Avatar
john73bb
Default Re: Serpentine Pulley Conversion, anybody done it (Flareside)
I would not use the long water pump, unless I could get a pulley with additional offset (might actually be cheaper to do that though). Since I am using electric fans, I could, but I think it will probably not cost much more to get a stewart reverse flow.
I'll take a look at the Autozone AC compressor and see how much work it will be to convert to that style. I can save the freon I have, and I do have a small stash of R12 somewhere too (stocked up before it became impossible to get -- it'll be my retirement now should I decide to sell it :) ). I think I can route the belt to allow for my standard rotation power steering.
I may have to build some spacers to get all the components at just the right forward spacing, but that shouldn't be too hard since they will no longer need to be adjustable.
Old Jan 30, 2002 | 04:32 PM
MassVette's Avatar
MassVette
Any thoughts?
John.
There are NO inexpensive serpentine setups that I know of. Sorry.
Here's my Street & Performance setup on the ZZ/502 (hope the pics are back)........
