Rotor runout . . . HELP!
Old Mar 31, 2009 | 11:43 PM
redman76's Avatar
redman76
St. Jude Donor '09
Default Rotor runout . . . HELP!
I don't get it? What am I missing? This is my first time shimming the rotor runout and I'm not sure what to do next. I indexed the rotor by mounting the dial indicator on the frame and placing the needle on the backside of the rotor.
I made sure the needle was positioned at 90* to the rotor.
To have consistent measurements, I moved the dial indicater to the backside of the rotor so I would not have to move the dial each time I rotated to the next index. I torqued the lug nuts to 40lbs each time. When I measured the total runout as I indexed the rotor, it was within .001 each time.
I was expecting there to be a difference from one side of the rotor to the other and I would shim the low side. But what does it meant when each index/hole is that close?
Old Apr 1, 2009 | 12:11 AM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
I am sorry as I do not see a problem here? If you are within .001 leave it alone As for both sides of the roter they should be the same. Now go on to the next 3 rotor's
From what I can remember you would like to shoot for .003 run out or less.
Old Apr 1, 2009 | 12:31 AM
my 76 ray's Avatar
my 76 ray
There must be something wrong. It's within spec the first time.
Some people just can't deal with success.
Old Apr 1, 2009 | 12:34 AM
SHAKERATTLEROLL
I think he was just pulling our legs lol. And might even be a small bragg lol. But he does have 3 left lol.
Old Apr 1, 2009 | 10:41 AM
redman76's Avatar
redman76
St. Jude Donor '09
No, I don't think I'm doing something right here. You can see the .018/.019 "wobble". My understanding is that I'm trying to get that down to .002. I'm not sure if my measring process is wrong or what. It's just not making sense to me.
Does this mean it doesn't matter which hole/lug combination I use from my index, just pick one and shim to .002? Did I just answer my own question?
Old Apr 1, 2009 | 12:18 PM
Brooklinite's Avatar
Brooklinite
If you're already at .001 (ie. damn-near perfect) why would you want to get to .002?
Maybe it's the way you're describing it but it doesn't seem like there's a problem.
Old Apr 1, 2009 | 12:24 PM
Mike Ward's Avatar
Mike Ward
Your post is still dated before the official cut-off for April fool's jokes. Not withstanding that, I'm confused.
The dial indicator should be in constant contact with the rotor surface and positioned so that the indicating needle is set in the middle of it's travel. The dial should then be rotated so that the needle is at 0 (zero). Rotate the rotor slowly through 360 degrees and record the variations from zero as either positive + or negative - numbers.
The delta will indicate how much runout you have and where the high and low spots are. Index the rotor to a new orientation to the hub and try again to see if it's better or worse. Pick the best indexing and shim accordingly. Better yest would be to have the rotor and bub machined as a set like the factory did.
I don't think the measurements you have to date are of much use.
Old Apr 1, 2009 | 05:11 PM
redman76's Avatar
redman76
St. Jude Donor '09
Originally Posted by GTR1999
What is your reference to 018/019"? Find the lowest spot -0- the indicator and check it 360*. The way you're showing it is 001 out but there's no reference to -0-
My numbers are the total runout or the delta between the pos & neg. I set the lowest spot to zero and rotated the rotor which gave me the .018. Then I pulled the rotor and rotated one hole and measured again. This time the delta was .019. I repeated the process for all five holes and the results are what you see. Do I need to note for each hole the values to the left and to the right of 0? Then which one do I select to shim?
Old Apr 1, 2009 | 05:17 PM
redman76's Avatar
redman76
St. Jude Donor '09
Sounds like this is the part of the process that I'm missing. I'm not sure which is the best index to use. Unless I have a revelation and figure it out tonight, I'll record my numbers and post so you guys can look at with me. I can be pretty hard-headed, but I usually get there.
Old Apr 1, 2009 | 05:30 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
No need to remove the rotor and turn it to the next hole each time. When you get the runout, find the low spot, add a shim under the rotor at the low spot. Put your lug nuts back on and torque, reread the runout. This should get you closer to the goal. Keep working like this and you should get there.
I hope this makes sense.
Old Apr 1, 2009 | 05:39 PM
Mike Ward's Avatar
Mike Ward
It seems that there is only .001" difference from the best indexing to the worst. This indicates that your rotor (like most) is almost dead flat. Pick the best of the lot and start shimming from there. You want to add shims at the spot where the rotor is closest to the dial indicator.
Old Apr 1, 2009 | 06:47 PM
redman76's Avatar
redman76
St. Jude Donor '09
Thanks Mike, I'll try that tonight and let you guys know how it went.
Old Apr 1, 2009 | 09:09 PM
Oldguard 7's Avatar
Oldguard 7
Hmm, Maybe I got lucky. When I replaced all the rotors on my Vette last year I did not check for run out and my brakes don't suck air. Replaced RF and RR calipers, replaced all bleeders with check ball (speed) bleeders, bled system with Motive pressure bleeder, and viola!!! Nice firm pedal. Car stops on a dime and gives you 9 cents change. (hope I didn't jinx myself) Good luck.
Old Apr 1, 2009 | 11:38 PM
redman76's Avatar
redman76
St. Jude Donor '09
Got it figured out tonight . . . Left Front - .003 Right Front - .0025 and yes I did use Natural Light shims! !!! Thanks for the help!
Old Apr 2, 2009 | 07:37 AM
corvetteterry78's Avatar
corvetteterry78
Cruising
do the shims go between the rotor and spindle or rotorand wheel
Old Apr 2, 2009 | 10:35 AM
redman76's Avatar
redman76
St. Jude Donor '09
Rotor and spindle.
Old Apr 2, 2009 | 12:29 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Redman I was just looking at the other pics you put up on Photobucket.
I cant tell from the pics, but you did put the rubber seal around the spindle between the knuckle and the backing plate didn't you?
Could be just the way its pictured but it looks like the seal is on top of the backing plate.
To Rotor runout . . . HELP!
Old Apr 2, 2009 | 02:34 PM
Ironcross's Avatar
Ironcross
Take the rotors to a good auto parts and have them machine cut a few thousands to make the rotors true and be done with it. I cant understand why so many people with Vettes dont get it....
Old Apr 2, 2009 | 02:55 PM
redman76's Avatar
redman76
St. Jude Donor '09
Are you talking about this? I placed it between the spindle/knuckle and the brake shield.
Yeah, I just looked at the pictures myself and it does kind of look like it's on top, but it under the shield.
Mike Ward's Avatar
Mike Ward
Without being rude, they don't get it cause it's not true. The OP has already determined that his new rotor was flat within .001". I've never seen a new rotor that was out of spec and even if it were dead flat it won't help a hub that's got a surface that's not perpendicular to the shaft.
