2 or 4 bolt main blocks
Old Jan 30, 2002 | 11:09 AM
Corvettelvr73's Avatar
Corvettelvr73
Default 2 or 4 bolt main blocks
I have a 1973 with an L-48 motor. Does anybody know if it is a 2 bolt or 4 bolt main block? Any help is needed?
And also what is the difference in the two?
Old Jan 30, 2002 | 11:12 AM
fauxrs's Avatar
fauxrs
Default Re: 2 or 4 bolt main blocks (Corvettelvr73)
Te L-48 is typically a 2-bolt motor. Not that this should worry you as the two bolt can handle a whole heck of a lot more than most people give it credit for. IMO, for a street motor the only advantage to a 4 bolt is bragging rights when bench racing :lol:
Old Jan 30, 2002 | 11:19 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Re: 2 or 4 bolt main blocks (fauxrs)
I think the only need for a 4 bolt is high rev'ing and brutal torque motors. A 2 is perfect for street apps.
Old Jan 30, 2002 | 11:24 AM
Tom73's Avatar
Tom73
In '73 the L48 was two bolt and the optional L82 was 4-bolt. Only differences in the block is that the L82 has 4-bolt main caps on the three center main caps. The L48 has 2-bolt caps on all 5 main caps. But engine differences are alot as the L82 has heavy duty components in the crank pistons etc.
As has been said, the 2-bolt should hold up okay for most any street application. Now if you are running NOX or supercharger you will probably want to go with 4-bolt mains.
tom...
Old Jan 30, 2002 | 01:31 PM
Shark Racer's Avatar
Shark Racer
Anyone have any ideas how the GM GW 350 compares to the L-48 block? I know the LM-1 has a 4-bolt main, but not sure about crank and rods and all the rest.
Old Jan 30, 2002 | 02:40 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Default Re: 2 or 4 bolt main blocks (Pacin'California)
Standard truck parts in the GM crate motor, cast crank, rods and pistons. At least that's what the guy at GM told me. ZZ-4 has forged crank.
Old Jan 30, 2002 | 03:02 PM
dladd74roadster's Avatar
dladd74roadster
Default Re: 2 or 4 bolt main blocks (Smokehouse69)
I have heard of some L-48s that had 4 bolt mains. Here's the way the story goes:
If there was a shortage on the line, they would substitute L-82 blocks and use L-48 internals. But they NEVER were allowed to substitute an L-48 2 bolt block for an L-82. I have a feeling that there weren't that many 4 bolt main L48s though.
dl
Old Jan 30, 2002 | 05:57 PM
Tom73's Avatar
Tom73
Default Re: 2 or 4 bolt main blocks (dladd74roadster)
The blocks were the same except for 6 extra holes for the three 4-bolt caps. Would have been very easy to use the L82 block but use the 2-bolt caps and leave the 6 extra holes empty :rolleyes: Why use the more expensive 4-bolt caps on the L48?
tom...
To 2 or 4 bolt main blocks
