Patriot Heads
glad i read this post
best regards
Arne
http://www.yellowbullet.com/forum/sh...ad.php?t=49944
And if your thinking about Pro Comp read this. A stock, used vortec makes 30 more HP with a 40 CC smaller intake port than the CNC 210 Procomp. Wonder what kind of power the as cast 180 makes?
A set of AFR 195's dyno 102 HP higher than a Procomp 210 CNC head with a 15 CC smaller port. We buy an aftermarket head to make power don't we?
A Brodix IK180 as cast makes 65 HP more than a Pro Comp 210 CNC. Does that tell you anything about quality? That 65 HP will cost you a total of $400 on the same build with much better streetability and bottom end. Cheapest power you will buy.http://www.boatstoreonline.com/procomp.html
He is asking for Patriot cylinder heads not Procomps or all the other brands you happen know of. Yes, we have all seen those horror threads you refere to. Repeating this over and over again does not necessary make them more true.
Please attend to what Rayluca asks for.
Ray, take contact with Gunnar at PATRIOT PERFORMANCE and ask which cylinder heads will be the best fit for your demand. You'll probably hear a different story...
gunnar@patriot-performance.com
good luck with your inquiry Ray!
best regards
Arne
In other words, It's like Plato - The allegory of the cave...
How can one justify promotion or demotion of a product of there is no comparison to relative products?
I think bringing other head options into the coversation was relevant as can be.
BTW I have chineese made intake.. and I like it...
Take a look...
http://forums.corvetteforum.com/c3-t...0-68-64cc.html
Arneoe, do you work for Pro-comp? I'm beginning to wonder...
Also know what the sprint car guys run. No serious contenders use Pro Comp or Patriot and a lot of these guys are on a really tight budget building these cars out of pocket with no sponsership. One of my friends trashed an $8000 engine when his pro comp shaft rockers self destructed on his drag car. On the thread you started there were 2 people that used Pro Comp heads that both experienced catastrophic failure destroying their engine in less than 2 thousand miles. One was due to poor quality valves and parts, the other due to an improperly machined water port. That tells me the machining is questionable and the parts are questionable.
Like I pointed out Stock used vortec's with a 170 CC intake port outperform a new Pro comp 210 CNC head by 30 HP in a back to back dyno test. Use your heads, I am sure you will be very happy with them.
But you obviously have very little experience and also have no first hand knowledge of the patriot heads. Did you even look at the pictures on the Yellowbullet thread before recommending these? The castings and machine work are horrible. I would not even consider using or recommending a product made by any company that would let something like this leave the plant with their name on it but that is just me and my opinion which you feel is irrelevant anyway.
Take a look...
A.
the real question here is... do you give up??
Dude.... READ!!! you have real experts telling you real world truths and pointing out everything to you... again... you work for these Chines head guys or what??
I also think bringing Procomp into this discussion is relevant because it is my understanding Pro Comp, Patriot and RHS use the same castings in all three heads so you are right, it would be very difficult to tell the difference even if they fell on you. RHS does their machine work in the US and uses superior parts so they are a little higher. Close to the cost of a Brodix IK 180 which in my opinion, that don't matter, is a great 350 head for a very good price, that flow well and use top quality parts.
First Issue, standard rocker covers would not fit, they fouled on the (standard) rockers (top side). Patriot advice (via reseller) was to fit 100 thou longer pushrods. Did this but didn't solve the problem. Ended up using the extra wide fabricated rocker covers, that might be required for roller rockers, to overcome the problem.
Second Issue, most plugs were oiling up. Believe the problem to be that the rocker posts threads are drilled and tapped into the inlet port. The rocker post threads didn't have sealant applied, so oil was pulled down the threads by the vacuum. A fixable problem, but shouldn't have to.
Third Issue, if you place a square over the centre of the rocker posts, some line up with the centre of the valve, some don't.
Fourth Issue, on a couple of cylinders, and I forget which ones now, if you line up the rocker with the centre of the valve, the pushrod is on an angle because it fouls on the head casting.
Fifth Issue, there was no rocker to rocker post clearance, top side, with the valve closed. Remember, we're just talking standard 1.5 pressed rockers here. In my estimation, and I came to this conclusion by making a home made variable length pushrod, 200 thou longer pushrods would be required to give the necessary clearance.
As I stated earlier, I'm not knocking the product here, just stating the facts regarding my experience with this product.
can i just sumarize to save time.... patriot heads are s h i t
