Help from the C3 Vette Gods..
Got an 80 vette that I'm sticking the GM ZZ383 crate engine into. I'm going to use the ProFlow EFI system for induction so that means I have to upgrade the fuel system from carb'd f/p to EFI f/p.
I don't want the hum noise from an inline electric pump so my goal at this point would be to source a fuel tank from some later year vette that used an in tank fuel pump module. Obviously, the tank will need to fit up where the other tank is so that is a consideration.
This engine will be around 500hp once its all said and done. I know the stock pump from a stock vette production year that had an in tank pump will no where be enough to flow for that much hp so I'm wondering if you guys could kindly guide me with what year tank to use, a pump that would fit as a module but yet provide for the hp I'm wanting to run, etc.
I'm sure this isn't new when talking about projects so my hope is that, within moments of this posting, I'll get a response that will solve all my problems and possible provide me with the numbers to the next mega-millions lottery win.
Thanks guys!
Kurt
I just upgraded my 383 to a Mass Flo fueil injection. I am running right around 500 HP also. I am using a Walbro extrenal pump. It is very quiet. I cannot here it over the exhaust. If I just run the pump you can slightly here it but once the car is running I cannot. Here is my setup. Nothing wrong with an in tank pump but this is an option.
Thanks so much for taking the time to post that up. The goal was to have as quiet an exhaust I could get but not choke up too much of the hp. I take it your exhaust is mild when you say you can't hear the pump over the exhaust system or is your exhaust aggressive?
Also, I believe my year came stock with an aluminum driveshaft. Did you upgrade your driveshaft when you built yours up or did you you leave it stock?
Thanks again!
Kurt
I wouldn't worry about your driveshaft. It's your stub axles, u-joints, half shafts, and rear-end that'll break long before your driveshaft.
Also, there are in-tank pumps you can use Aeromotive has one (A1000 or something like that) that can be mounted in the tank. Trying to find another tank that already has everything in the right spot might be very difficult and you'll probably find that just modifying your existing tank might be the easiest route. More useful would probably be to ask around which pumps are quiet. 500hp isn't a very large hurdle for most electric pumps. Heck, a stock mechanical pump will handle 500hp easily. There's also the RacePumps to look at which is a mechanical pump that can supply an EFI setup.
http://forums.corvetteforum.com/c3-t...p-options.html
j/kSeriously though, I'm going to tap you two specifically for info if you don't mind when it comes time to tune it.
Thanks again fella's. Enjoy your weekends.
Kurt
So, thanks to all (I should have said).
I definitely appreciate the guidance about the driveline. I'll make sure to redirect my concerns there. Thanks again!
Kurt
Thanks,
Gordon,
Even though I know the emissions will be worlds better than carbureted setups, the state yearly emission check is a concern of mine. I don't know what state you hail from but did you have any issues running this setup with the PROflow and negating the EGR system?
Texas does a visual check but the other portion of the test is safety checks only (wipers, brake light operation, etc.). Silly, because it doesn't matter if the EGR is working or not...it just has to be there.
I don't mind trying to hunt someone down and throw a c-bill at them to give me a sticker, but I'd like to incorporate everything that I need to to be in order to be 'legal'.
Since you've done this, what did you end up doing in this regard or because your state doesn't care one way or the other, did you just worry over it?
Willlee,
I'm going to list a full build list after I'm done if you're interested. I'll make sure to post it up here once I'm done. 500hp would be impossible with 'just' the setup I've noted so far. Also, my goal is 'around 500hp' so anything just shy of that, I'm going to be stoked about.
You installed the 700r4 correct?
What challenges did you meet with in regard to linkages, etc. ?
Did you end up going with a better gear in the diff then since you have overdrive?
If its not too much trouble, do you have a link to your build that I coudl peruse over?
Thanks!
Kurt
The upgrade from the original 82 CFI pump has been to go with either a TPI pump (85-91), which may not support your horsepower goals, or an LT1/LT4 (92-96) pump which may bre able to support the goals your looking for. You might need to go with a larger feed tubing inside diameter. these pumps "bolt in" to the existing 82 sending unit set-up.
I would post this same question on the C4 Tech section to see what they would recommend.
