Fuel return line ?
Did a lot of reading on this subject, got opinions that went both ways. In the end, it made sense to me to run the line as a vapor lock cure. Seemed logical that the ability for the system to circulate heated fuel not being used, back to the tank, would help keep the problem from ocurring. I am running the return line from a Mallory fuel pressure regulator, that is designed for this purpose (Mallory part number 4309). I have had a car that was prone to vapor lock in the heat of summer, it is a PIA to deal with. Needed a fuel pressure regulator, anyway, so it was just an extra line to run. Advanced search in archives will get you all the arguements for and against. Good Luck!
