sway bar bushings
Old Apr 3, 2009 | 10:31 AM
CorvetteStingray74$!'s Avatar
Default sway bar bushings
Which are better poly or stock bushings for a front sway bar? any opinions?
Old Apr 3, 2009 | 11:08 AM
gerry72's Avatar
gerry72
Rubber works. Urethane does do too. You'll not notice a difference in the car's handling with either unless this is a track-only car, in which case you should be using solid joints. The rubber will be quieter in all conditions. Urethane may squeek.
Old Apr 3, 2009 | 11:11 AM
Thanks gerry i will go with the rubber, she wont be at the track much.
Old Apr 3, 2009 | 12:45 PM
Solid LT1's Avatar
Solid LT1
Poly bushings from Street Specialty that are made for our stock brackets are the best! I will try to find the guy's phone number for anyone interested.
Old Apr 3, 2009 | 12:57 PM
selectgear's Avatar
selectgear
From an originality standpoint the stock rubber is correct. It seems most bushings in the aftermarket today are poly.
Jeff
Old Apr 3, 2009 | 02:40 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
FWIW, you don't have to track you car to enjoy improvements offered by high perf bits, but I wouldn't bother with poly if you don't already have poly CA bushings, in which case it would then be worth something to you.
TSW
To sway bar bushings
