yes, but it's not wonder power gains. It gives your chevy a different sound and it runs smoother.
Gkull isn't supposed to be easier on the crankshaft its main contributing factor. Besides rollers I noticed comp cams makes off the self solid flat tappit cams with 4/7 swap.
Everything I have heard from guys that have tested them is that unless you have a full blown race car, the 4/7 swap is pretty much good for nothing.
Yea this is a mod that I'd pass on...myself. BEtcha 99.995% of the gains would be only noticeable on REPEATED, BACK TO BACK dyno runs, comparing cams with conventional ones.
While it's an interesting application, and I laud those who ground the cams & tested this stuff out, on the SBC motors it's not a winner. Perhaps other motors but not ours.
From: Graceland in a Not Correctly Restored Stingray
According to my understanding, here is the reasoning behind my choosing to go with a 4/7 swap in my new 427 BB build...
1) Better balance of peak loads on the crank journals; the 4th main having much higher loads than the 2nd in the 1-8-4-3-6-5-7-2 order, but the difference between the two is said to be significantly less with the swap. This supposedly also improves integrity of the oil films on the mains.
2) Improving A/F mix distribution to 7, which tends to be lean (especially with 180* manifolds), which should reduce the need for staggered jetting.
3) Having 4 & 2 exhaust events together apparently doesn't pose as large an issue as does having 5 & 7 together, as the former cylinders typically run cooler given they're closer to incoming coolant.
Given these and other lesser potential benefits, I really don't care if it makes any more torque or power. My $.02.
TSW
This is exactly why I believe I am going to go this way. I wasn't looking for horsepower, but the cooling and less strain on the bottom end is what I was looking at.
Will let you all know how I come out.
Thanks for the replies
My current SB 427 is running a solid roller with the 4-7 lobe swap. My engine builder recommended it for the reasons stated by Skunk. Originally built with it, I don't have a comparison to go by.
Personal observations show it be lopey at idle but smooth at the same time if you can understand what I mean....sort of wicked....gobs of torque from idle through 7000 rpm. Not radical duration, but lots of lift.
I don't know how much horsepower is added because of the swap, but I'm well satisfied with its behavior. See dyno sheet.....
TSW
The Chevy guys are doing it now (and have been for 12 years) w/ the LS motors.... And I don't think the cam pricing is anymore expensive.
