brake help
Old Apr 4, 2009 | 06:34 AM
tacjam3's Avatar
tacjam3
Default brake help
replaced master cyclinder & calipers bench bleed cyclinder tryed to pump up brake to bleed calipers but no presure. got vacume pump bleed calipers but dont have any presure to brakes.was wondering if that proporsioning valve moved
Old Apr 4, 2009 | 08:25 AM
JimT's Avatar
JimT
I would bleed the MC again. I helped a friend recently and it took several times to finally fully bleed the MC. His MC had a plastic fitting and hose kit that you use. We mounted the MC, filled it with fluid, installed the fitting and looped the hose into the reservoir and cycled several times.
Old Apr 4, 2009 | 09:24 AM
schmegeggie's Avatar
schmegeggie
Oh man! Not again!
Old Apr 5, 2009 | 10:56 PM
dburgjohn's Avatar
dburgjohn
went round and round with mine also, it was the valve. replaced it and bleed fine
To brake help
