Fixed the starting issue, and then.....
So, I went tearing around on some back roads, hit one turn fast, and after words, feel a wobble in the wheel. I get it back home, and am looking for the problem, and I notice 2 problems.
One is, on the VBP suspension I have installed, one of the bolts that holds in the rear springs to the dual mount system is MISSING. Like....gone. Just...not there anymore. So, only 3 small bolts are holding in the spring on that side.
As if THAT were not enough...I found out why the wheel felt wobbly. 3....THREEE, of the studs, snapped. As in, ONLY 2 studs were holding my wheel in place.
Time to get new studs for the rear wheels...and...while I'm at it....fronts too.
I can't even go into thinking what could have happened, and quite frankly...I don't really want to. Just home now, happy to be, and drinking some beers. Putting together a game plan.
A couple of years later a shop the deals only in Corvettes didn't tight the rear spring bolts under the diff. Can't trust anyone anymore, start at the front and work your way back, this goes for anyone reading this thread
I should also note that I am not completely innocent, here. I have wheels from a 2000 corvette...so they are considerably wider than stock, and with MUCH better gripping tires. I used 3 inch spacers in the rear to get em to fit. Maybe it was a bit too much for the old studs to handle...maybe they went, and began to wobble, causing the bolt to go in the spring mount....
Who knows. Honestly, who even knows how long I was driving around with a bolt missing?
Call VBP and ask....WTF? Why market a suspension kit that loses bolts?
Seems to me, this is a recurring problem, after reading some threads about it...
