I know we have all seen this thread before, but I simply can't stress this enough. For some reason, the bolts that hold the spring onto the mounts like to come out.
So, please, dear god, if you have this system installed, check that sucker from time to time. I didn't, obviously, and am now missing a bolt. Luckily, I got home just fine...but now I have to call VBP and see about getting a replacement. And also trying to find a solution to this problem.
Used a dab of blue loctiite on mine that will hopefully keep me out of trouble, but will continue to check, thanks for the warning.
ikwhite
Can you take a picture of which bolt(s) you are talking about? Also, is this the front or the rear system?
I have the front Performance Plus system, and getting ready to install it soon. Is this like what you have? Vette Brakes Perf Plus, front
Would blue Loctite hold it better?
Thanks for the heads up anyway!
Paul
I have that system in the front, and thus far, have had no problems. It's only the bolts that hold the spring in the rear that seem to like to come out...
