Elect. fan switch specs.
Old Jan 30, 2002 | 08:32 PM
korvettekev's Avatar
korvettekev
Default Elect. fan switch specs.
Does anyone know the temerature at which the stock electric fan switch (on a '81) turns the fan on and the temperature that it turns it off? I am thinking about using this switch to trigger a non-stock fan that I am installing. Thanks.
Old Jan 31, 2002 | 12:10 AM
DavidOrr's Avatar
DavidOrr
Default Re: Elect. fan switch specs. (korvettekev)
It's high, probably higher than you want. Mine in a 79' kicks on at 220 and back off at 200.
Old Jan 31, 2002 | 02:28 AM
Ingar, Norway's Avatar
Ingar, Norway
You find it in the GM shop manual electrical at my site, under technical
Old Jan 31, 2002 | 09:16 AM
73 Teach's Pet's Avatar
73 Teach's Pet
Default Re: Elect. fan switch specs. (Ingar, Norway)
Advance Auto sells an adjustable electric fan switch kit for $19. The temp probe is attached to the backside of the radiator. It's operating temp range is pretty broad. I opted for one of these since I figured that an in the block temp switch would probably be about the same money. I have not time to get mine hooked up yet because my project is not that far along.
Be cool!
"TEACH"
Old Jan 31, 2002 | 03:53 PM
john's '81 mouse's Avatar
john's '81 mouse
I agree with response from DavidOrr:
Comes on @ 220 and off at 200. I've seen aftermarket corvette suppliers who sell a replacement for this switch, which is installed in head between #s 8 & 6 cylinders, which comes on @ 200 and off at 180, if I remember correctly.
Check with Ecklers, Mid America, or Corvette Central, believe it was one of those.
To Elect. fan switch specs.
