Brake proportioning valve
Old Apr 7, 2009 | 10:21 AM
dp1969's Avatar
dp1969
Default Brake proportioning valve
Does any one know if the Power Brake cars and Manual Brake cars had different proportioning valves or do they use the same one. This is for a 1969 Coupe.
Old Apr 7, 2009 | 10:48 AM
wcsinx's Avatar
wcsinx
zip and ecklers both only show 1 part for that year
Old Apr 7, 2009 | 11:17 AM
mrvette's Avatar
mrvette
It's not really a valve, it's just a pressure differential switch so if one end looses pressure the switch is pushed and the light lights on your dash....other than that, it does NOTHING, except as a line coupling for the front end
really nothing to go bad, other than a leak from the switch, a O ring and a seal is about all it has in there....then the switch plunger...
should be simple enough to fix it, really....I took mine out long long time ago...
Old Apr 7, 2009 | 11:24 AM
dp1969's Avatar
dp1969
The reason for the question is I am converting a Manual brake car to Power Brake. As an after thought,(After new MC and PB) I spoke with a Customer Service person at Ecklers, they said I needed a new one. I don't think there is anything wrong with the original. I was just under the impression that there were two different versions for Power and Manual. Or did Ecklers just need to sell some parts.
Old Apr 7, 2009 | 11:51 AM
pws69's Avatar
pws69
For 69, there is one part - it is a differential switch (not proportioning) to block the path that fails.
Yours should be fine if you had no troubles with it previously.
Old Apr 7, 2009 | 12:02 PM
mrvette's Avatar
mrvette
Old Apr 7, 2009 | 12:12 PM
wcsinx's Avatar
wcsinx
Do you have any pics of what you ended up with? I want to plumb mine out too.
pointless P.O.S. in my opinion
Old Apr 7, 2009 | 01:16 PM
stingraymaniac's Avatar
stingraymaniac
I removed mine when i changed brake lines,I just got new lines all the way upp to the brake master cylinder.
And a T split on the front lines to each wheel,Brakes are perfect now
To Brake proportioning valve
