69 435 tri-power tricks?
metering plates for the outboard carbs because the original ones were so pitted. Someone had also put
the screw in the linkage to pre open the carbs and
I know that is bad business. Im sort of a Holley guru
and know the 4150 carbs very well but not the 2300.
Any little tricks a veteran can offer me that will make
these things perform their best would be appreciated.
1st, and foremost, don't re-engineer the OEM secondary linkage system, but do take time to adjust it precisely and according to the book (this is no place to grow a brain and end up doing a "Bubba")...
2) Verify the power valve is a proper match for your vacuum signal...
3) Install the weakest secondary vacuum pot springs (kit #20-13) you can get away with without bogging, per actual road testing...
4) Remove the fuel bowl inlet filters and install a significantly larger one upstream of the carb...
5) Index the needle & seat (Viton) windows oriented away from any fuel bowl obstruction, as best you can...
6) K&N filter...
If you need any renew kits, I've still got a few, and if you don't have these links...
http://www.holley.com/data/Catalogs/....pdfHere's
http://www.holley.com/data/TechServi...ded%20View.pdf
Hope that helps a little. If this all sounds routine, good for you (or any other viewers).
TSW
