Fuel pump push rod
Old Apr 8, 2009 | 06:43 PM
Phil Zell's Avatar
Phil Zell
Default Fuel pump push rod
Those of you that are running retro hyd roller cams and using mechanical fuel pumps, what push rod are you using ? and best place to buy one. I finally made the plunge and don't want to mess up my new cam.
PZ
Old Apr 8, 2009 | 07:19 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I have the Comp Cams roller pushrod in my 427ci small block with a billet solid roller cam, if it's got a wheel on I have it in my motor
http://store.summitracing.com/partde...9&autoview=sku
Old Apr 8, 2009 | 07:48 PM
C3 Stroker's Avatar
C3 Stroker
I used a Moroso lightweight pushrod in my former 383 and present 427 SB. I believe it has a hardened end....it has worked well for me with both hydraulic and solid roller cams. If it's lightweight, it's in my motor.
Link: http://store.summitracing.com/partde...0&autoview=sku
Old Apr 8, 2009 | 08:45 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Using a Billet bronze tip fuel pump push rod in my 406 SB.
Old Apr 8, 2009 | 09:24 PM
Phil Zell's Avatar
Phil Zell
Where do you buy the billet bronze rods ?
Old Apr 8, 2009 | 09:32 PM
SmokinBBC's Avatar
SmokinBBC
Bronze tip. Jegs has them. I think they are Comp Cams.
Old Apr 8, 2009 | 10:02 PM
Glass Act's Avatar
Glass Act
Phil Zell, SmokinBBC is right, Comp Cams. I decided to use a bronze tip rod for extra protection against any cam wear. I'd rather buy a new rod over a new cam, but thats my two cents right or wrong.
To Fuel pump push rod
