Luggage rack
Old Apr 8, 2009 | 06:53 PM
lagnaf's Avatar
lagnaf
Default Luggage rack
I'm planning to remove my luggage rack soon and I'm wondering if there are any helpful tips I could use. I'm guessing I'm going to have to drop the tank to get to it also.
Anything tricky stuff I need to know?
Old Apr 8, 2009 | 07:40 PM
dmayhew's Avatar
dmayhew
I see no reason to remove the tank. The screws thread into a rubber insert that has a brass nut made into it. As you tighten the screw the rubber insert bunches up under the body panel.
Remove all the screws and then the rubber inserts should pull out
David
Old Apr 8, 2009 | 08:05 PM
71coupe454's Avatar
71coupe454
My rack is off but them rubber pieces are in there pretty good. not tried real hard yet just tried to work one out and seen it might be a pain so I havent got back to that yet. some wd-40 might help them slide out better.. its the bodywork you do to cover the holes you need to search for info on. I have been told they will show back up no matter what, I dont know about that but I will sure be trying to find the best possible way when I do it.
Old Apr 8, 2009 | 08:12 PM
dmayhew's Avatar
dmayhew
The OP has a different outlook. He will be filling the holes on his car anyway , so he can pull the old ones out with more aggression.
In your case 71coupe454 , you could take a razor knife and cut the insert and push the lower part down and let it fall to the top of tank and on to the floor.
David
Old Apr 8, 2009 | 09:46 PM
71coupe454's Avatar
71coupe454
Hey there ya go, just cut it, good idea, just like a valve stem, that should have been my first thought, I have only change a few thousand of them.. thanks
Old Apr 9, 2009 | 12:27 PM
lagnaf's Avatar
lagnaf
Actually I'm removing the rack so I can have it rechromed. Otherwise I like where your head's at.
Old Apr 9, 2009 | 07:20 PM
71coupe454's Avatar
71coupe454
oh I see.. then you have no worries.. just take the screws out and lift it up. watch the spacers/risers so none drop and hit the paint
Old Apr 10, 2009 | 01:08 AM
lagnaf's Avatar
lagnaf
Thank you sir. Sage advice.
To Luggage rack
